Old 12-25-2005, 09:19 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Lowering the rear with coils- track bar?
I am planning to drop the rear of my 70' with either 4" or 5" coils. How much will this shift the rear of my truck?. I'm assuming the 5" will shift it to where I need a track bar. Correct?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-25-2005, 09:41 PM   #2
cableguy0
Re: Lowering the rear with coils- track bar?
thats definately enough that you will need and adjustable track bar
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-26-2005, 12:44 AM   #3
SCOTI
SCOTI's Avatar
Over 5" will require adjusting the length of the track bar which can be accomplished different ways. Two of those ways are cutting the stock bar to the desired length required to center the rear @ the new lowered ride height or spending the money for an adjustable bar.
The adjustable bar is easier & modifying the stock bar is less money. Which do you have more of: time or money?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-26-2005, 09:18 AM   #4
mike nutt
69fatmotor
mike nutt's Avatar
70c10, heres a picture of the rear of my '69c/10 with 6" springs and an adjustable super track bar from ECE. the longer bar greatly reduces side to side movement during suspension travel.
mike nutt is offline   Reply With Quote
Old 12-26-2005, 09:37 AM   #5
70c10
67-72 Addict!
70c10's Avatar
Thanks guys!
Jim
Old 12-27-2005, 02:35 PM   #6
70c10
67-72 Addict!
70c10's Avatar
After reading this again, Scoti says "over" 5" needs one and mike nutt has a 6" drop. Is it possible 5" may work without the adjustable bar?.
Jim
Old 12-27-2005, 02:49 PM   #7
cableguy0
going 5 your definately going to have the rear shifted to one side screwing up all the suspension geometry.
Old 12-27-2005, 07:57 PM   #8
SCOTI
SCOTI's Avatar
The more you lower it, the more the rear shifts over to the pass side.
I know you can get away w/a 5" drop w/o an adjustable bar (or longer, super track bar) because my buddy was too cheap to buy one when we did his 65. Whether it works or not on your combo is directly related to how wide the wheel/tire combo is & what kind of backspacing you have.
To make sure the tires won't rub, use an adjustable bar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 12-27-2005, 09:42 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Thanks Jason and Scoti. Clear as mud now!
Jim
Old 12-27-2005, 09:50 PM   #10
cableguy0
lol alright. think about it this way. every little bit the truck lowers the track bar becomes more paralell with the rear instead of an angle sooo... the rear gets pushed further to the passenger side with every inch you lower it down. the truck will actually track crooked down the road. you need to have the rear lined up with the front end otherwise you will never have proper alignment on the truck.plus it will stress the bushings in the trailing arms a lot.
Old 12-29-2005, 12:56 AM   #11
1969burb
on the topic of adjustable track bars, what applications require going from an adjustable bar to a track bar kit? If I understand correctly the track bar kit changes the mount point on one end of the bar, but I guess I don't get the circumstances where that becomes necessary. I have an adjustable bar that I have not installed yet, I have 4 inch dropped coils on the rear of my burb and was planning on putting the bar and a set of 1 1/2 inch lowering blocks on at the same time.
1969burb is offline   Reply With Quote
Old 12-29-2005, 11:00 PM   #12
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Anything lower than 4" I would recommend at least a super track bar. The adjustable track bar that has a different mounting point is obviously ideal but not totally necessary IMO. I'm at 5-1/2" drop out back (4" coils and 1-1/2" blocks) and I've got CPP's super track bar, which is basically similar to the stock panhard bar but it can be lengthened or shortened to accomodate a particular drop. My rear end is centered and I don't have any issues with my truck not tracking straight. Back on point.....If you go more than 4", you're gonna need at least the super track bar as the rear end DEFINITELY gets off center and becomes worse the lower you go.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 12-30-2005, 12:45 AM   #13
1969burb
thanks 67 Fleet, I bought my adjustable bar without even knowing there were different options on the mounting points. sounds like I'll be just fine with what i've got since its working for you. I appreciate the reply!!!!!
