Old 12-26-2005, 01:04 PM   #1
aggiedave98
where to get window motors
Where is the best place to buy the power window motors?? I need to buy on for my '89 Suburban window (as per the previous posts...)
Is lmctruck any good?? Dealer??
thanks.
aggiedave98 is offline   Reply With Quote
Old 12-26-2005, 01:41 PM   #2
fiream
Re: where to get window motors
I can't suggest a good place to get them but before you jump off and buy one make sure it's really the motor. GM has used some really crappy switches on their power windows. If it's one of the chrome ones, the contacts may be chewed up causing the motor to get low voltage. If the voltage goes down, the current draw goes up and overheats the motor. You might try bypassing the switch with a heavy gauge jumper to see if that has any effect. Also, if you have a meter it would help if you could see what the voltage drop at the motor is when it's in operation.
I didn't see in your posts what year it was so I thought I'd throw that at you. If it's one of the late models with plastic switch buttons I don't know if this will help. Maybe they finally corrected the problem but I have no experience with them.
Good Luck,
Fiream
Just noticed you had the year in this post. Sorry I missed that. I went and read your other post and then came back to this one and replied without re-reading this one. Did the 89's still use the chrome switches?
Fiream
fiream is offline   Reply With Quote
Old 12-26-2005, 07:17 PM   #3
bisquik65
bisquik65's Avatar
What door do you need it for,right,left ,front or rear? I have 5 burbs for parts and have good used motors here...$20 includes shipping.
bisquik65 is offline   Reply With Quote
Old 12-26-2005, 09:17 PM   #4
bigarmzz
bigarmzz's Avatar
i hate power anything in these trucks....
...but man, $20 for the motor is a smokkiinnnnnn deal erick!!!
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 12-27-2005, 10:43 AM   #5
aggiedave98
Fiream, yes it's an '89 and yes, it has the little chrome switches...
bisquik65, let me start and make absolutely sure it's the motor first. I'll try bypassing the switch and seeing what the voltage drop is. If I still need a motor, I'll let you know. Thanks for the offer!
Old 12-27-2005, 08:22 PM   #6
bisquik65
bisquik65's Avatar
Take your door panel off,Plug the switch back in,And try it,If it dont work,try smacking the motor itself with a small hammer...If it starts working,the brushes are bad in the motor...And check one more common thing...Inside the rubber boot in front of the door...Gm's and bad to break i wire from open/close all the time...and that may be it too....Make sure you have power to the switch...Let me know,Glad to help,Erick
Old 12-30-2005, 01:14 AM   #7
aggiedave98
Guys,
The motor actually works, but is really slow and eventually overheats. If I help pull it up or push it down w/ my hand, I can get it to go up or down without overheating, but that's it.
I hopefully will get to try bypassing the switch tomorrow...
Old 01-03-2006, 07:16 PM   #8
dapolice1
We can roll all Day!!
I still need to know who sales the NEW/ Remanufactured motors for the burbans.
I need to replace mine, but want to use reman or new units.
bisquik how many you have? In case I can not find new units.
dapolice1 is offline   Reply With Quote
Old 01-03-2006, 10:52 PM   #9
WLPTMP
Active Member
WLPTMP's Avatar
i can get new ones for u from gm where i work
WLPTMP is offline   Reply With Quote
