Junior Member
brakes
has anyone seen a 68 chevy truck 3/4 2wd with rear drums 12 inch not 11 inch has rear leaf springs and is a custom camper
having trouble with rear brake adjust assy. ................................................................................................. |
its all about the +6 inches
Re: brakes
is it a big block?
Does it have the Eaton HO52 rear end, or the Dana? |
Old Skool Club
![]() Join Date: Jun 2001
Re: brakes
GM offered different diameters of drum brakes; but you had to buy the right truck to get the larger sizes. C10's had 11x2-inch drums all the way around, while C20's had 11x2.75 inch drums. K20's had 12x2-inch. C30's had 11x2.75-inch drums in front, and 13x2.5-inch drums in back.
Early Classic Enterprises offers an 11x2.75-inch conversion to replace the 2-inch wide rear drums, if you want to go that route. It is essentially the 3/4-ton rear brakes on a 1/2-ton axle. Pull the axles and backing plates with brake parts attached. Install new backing plates and axles and new brake parts and get more braking power. Based on brake lining area in square inches, you'll jump from 83.5 square inches (rears) to 119 square inches (rears). If you have discs on the front, overall braking should be greatly enhanced. But, to answer your question, I don't find a 12-inch drum listed in my '69 Truck Data Book. GMC? Could be different. But, the leaf springs were an option on the Chevy's and there was nothing noted to indicate that the drum brake diameter would be different. However, anything is possible in a world where there is interchangeablity of parts. I wouldn't be surprised if somebody put a FoMoCo rear end under one of our trucks!!! Yeah....gimme a good 9-inch rear end, with some 5.38's and.....a big ole pocket full of gas money.....
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Re: brakes
The dana rears have 12 x 2 1/2" brake shoes and the eaton has 11 5/32 x 2 1/2" shoes I think. I found a listing in my '69-'70 truck parts book, it lists 12 x 2 1/2" brake shoes for a C20 with the Dana axle, that's probably what you have.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Re: brakes
where can I buy the 12 inch drums and shoes
