Old 07-14-2002, 04:00 PM   #1
bigfish_63
Drop ?????????
What would happen if you just cut you coil springs to drop your truck can some one help me please
bigfish_63 is offline   Reply With Quote
Old 07-14-2002, 04:57 PM   #2
Low69CST
You can only do this to your front coils. What happens is you get a stiffer ride, just like with the ones you can buy. The trick is figuring out how to cut them so you get the drop you want. Its not a 1:1 ratio.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 07-14-2002, 04:59 PM   #3
bigfish_63
So you can not cut the back coils and if you cant what is the easiest way to drop the rear
Old 07-14-2002, 05:05 PM   #4
Low69CST
if you just want a couple inch drop, you can make some blocks, if its more than a couple inches you have to buy springs. You could heat them, but you will absolutely destroy the ride. The springs on the rear have pig tails on each end. So you cant cut away from that.
Old 07-14-2002, 05:18 PM   #5
PushinPebbles
My dad's 68
PushinPebbles's Avatar
hmmm....
i got my rear springs till they are on the frame rails...................but im in the younger crew so i can put up w/ the ride.............................im waiting on the funds to get bagged too so ..........u make ur decsion
Jack M.
67 C-10 SWB 355 built T-350 tranny hurst shifter 17x8in KMC's on michelins, clear tails and back up lights slammed**UPDATE i have decided on my bag setup and will post further info when i recieve all the parts
88 1/2 ton suburban 4x4 350/700R-4*having a 9 in lift w/ 38 in tires
4 12 inch Lightning Audios
87 silverado 3/4ton jacked up 10-12 inches black and rubberized bed coating 35 in michelans ******************************
Dad's truck
68 C-10 stepside, 468 BB, tubbed, weld wheels, Nason black,lots more
grand dads truck 68 C-10 stepside
fuel inj. 350/700R-4*soon in audi silver*
84 toyota pickup 22R 5 speed 2WD slammed, shaved and all the body lines filled w/ buickGN scoop,bout to be sprayed in 2003 mustang green metallic w/ silver flames
S/N=BIGGYTYME@aol.com
(hydros)
"No fat chics, truck will scrape"
PushinPebbles is offline   Reply With Quote
Old 07-14-2002, 05:26 PM   #6
SCOTI
SCOTI's Avatar
You could cut the rears but it would be more trouble than it's worth. In the past when we were poor(and drop springs weren't readily available) we would fab a short cup the outside dia of the spring and sandwich it between the bottom of the frame rail & the top of the spring. The depth of the cup was around 3/4" or so, just enough so the spring wouldn't be able to move around. If you look under GM A/G body cars the rear springs aren't bolted in @ the top so this works but like cutting the fronts it's hard to control the springrate vs amount of drop. You are better off using lowering blocks + shorter aftermarket coils w/proven springrates IMO.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-14-2002, 06:41 PM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Lowering springs are only about $100.00-120.00 a set.I would spend the $$$ and keep the ride because it would be safer and keep you from going to far to use the originals.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 07-14-2002, 06:49 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Keep in mind, if you go over 2 inches with a spring only drop, (either cutting or purchasing) you will start to get bump steer from bad geomitry angles.
