12-26-2005, 11:52 PM | #1 |
what gears to use
i have asked this before,but i would like some more insight,i have stock 3.08 gears in my 72 4x4 and it seems a little sluggish,oh yeah,i have 35 inch tires,anyway,what do you guys run on yours and how well do they do,any difference in mpg,im thinking 3.73 or 4.10,i dont do alot of off roading at all,its my daily driver,i would just like some more insight......mike
21 2500hd duramax 58 apache HILLJOB GRAPHIX--for all your graphic needs My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=542497 LS ENGINE SWAP INFORMATION THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=377348 4l60 to an NP205 http://67-72chevytrucks.com/vboard/s...43#post3697343 |
12-26-2005, 11:57 PM | #2 |
Re: what gears to use
With the 35" tires, I would say 4.10's
12-27-2005, 12:08 AM | #3 |
Fabricate till you "puke"
I would go 4.10, or 4.56 with a 35" tire. I guess it just depends if you do a lot of hyway driving, or mostly in town? my calculator says 3000 @ 68 mph with the 4.56's.......which isnt really too far out there L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
12-27-2005, 07:20 AM | #4 |
On a 1/2t that would have originally had about 30" max.dia.tires and now has 35s,I`d say you`d want 3.73s to be close to that ratio.You`ll probably come out a little higher(lower no.).I would go with 4.10s.You`ll end up with between the 3.08s & 3.73s.Ratio isn`t the only thing that taller tires change.Figure you`ve added more rolling resistance,taking away a little power.So you want to come out a bit lower than your original mark to keep the same power.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 12-27-2005 at 07:21 AM. |
12-27-2005, 07:22 AM | #5 |
so,how exactly do i figure out how to calculate that,in a post above,he said at his calculation3000rpm at 68mph,how would you figure that
12-27-2005, 09:40 AM | #6 | |
http://www.1bad69.com/calc.htm You may also find some other calculators that let you compair 2 different setups. L
12-27-2005, 10:16 AM | #7 |
1968 C20 Vortec Beast
What kind of trans are you running?
I used to have a 4x4 77 model with the same gears as yours. I got rid of the 350 trans that was in it and went to a 700r4. This trans has the lowest first gear you can find, even better than the 400. This helped out dramatically for taking off from a light. Normal traffic stopped walking away. Eventually I also went to a 3.73 gear. The combonation of the two made the truck great offroad and on. 16 mpg highway. With the 35's I had on mine I could run down the highway at 2000 rpm.
Ugly or not it still kicks a**! Last edited by stueber68; 12-27-2005 at 10:17 AM. |
12-27-2005, 10:33 AM | #8 |
I had the 3.08's like you and went to 3.73's (Running 35's) because with 3.73"s you can just change ring and pinion. If you want 4.10's you will have to change carrier. Mine is a lot better with the 4.10's. Going down the interstate at 70, I'm running around 26-2800 rpm's. I like the 4.10's the best from my 35's. You will tell a big difference going from the 3.08's to the 3.73's if thats the way you go.
We have calculator's over at myoldtruck.com to figure your rpm's. http://www.myoldtruck.com/calculator...alculator.html Last edited by Mudder; 12-27-2005 at 10:39 AM. |
12-27-2005, 11:21 AM | #9 |
user # 2756
I've been there too, 35s w/ 3.08s. then I got my GMC and went 31s w/ 4.10s, sold it with 35s and the same 4.10s. My Chevy had 4.56s and 35s. Now I have 4.10s w/ 33s, and fairly happy, probably go 35s one day.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm |
12-27-2005, 11:32 AM | #10 |
I have a friend that tags along sometimes and I mean tags along. He has a 3/4 ton with 4.56's and a 4speed (35's) and he has a hard time keeping up on the freeway. His old truck is wound pretty tight going 70.
12-27-2005, 03:42 PM | #11 |
I have the same problem, 35" tires with 3:08 gears. I will probably go with the 3:73's because it is a pavement pounder though I once owned a 1/2 ton Chevy with 36" tires (measured) with 4:10's and that combination produced better gas mileage than the stock 3:08's with stock tires.
71 Cheyenne Super 4X4 SB 72 Cheyenne Super 4X4 SB 72 Cheyenne 4X4 SB |
12-27-2005, 06:49 PM | #12 |
ok,so where do i find a calculator to determine what my gear ratio will actually be,once i put the 3.73 in,like right now,w/ my 35 tires and my 3.08 gear,its actually like a 2.42 gear all together,i seen it on here once,but cant seem to find it,also,what kind of mph should i be looking at w/ 3.73,around 10,thats really not bad for me
12-27-2005, 07:55 PM | #13 |
Try this link...http://www.csgnetwork.com/multirpmcalc.html
01-05-2006, 12:20 AM | #14 | |
Geared for Collision
i have the same set up and yeah at 70 its screaming, 70 is about max speed i ever go.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
01-06-2006, 06:16 PM | #15 |
one of my trucks has 3:73s and 36' SXs. I drive it on the road, wheel, highway. I think it's perfect. Once I get the VSS hooked up so the speedo and engine stuff, it will run alot better and more mileage, too. The burban that I'm building will have 3:08s in it, with a 4 speed and 33s. This will be a driver, no wheeling here. And if it doesn't sell, an alum head 468 to motorvate it.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
