Old 12-27-2005, 02:55 AM   #1
muddpile
muddpile's Avatar
Removing ignition?
I've removed everything from the dash/interior of my truck in preparation for painting, but I can't seem to get the igniton switch out of the dash. I tried turning that housing it fits in with a flatblade screwdriver, and that loosened it but it doesn't want to take it right out. What am I missing? Thanks!
muddpile is offline   Reply With Quote
Old 12-27-2005, 05:17 AM   #2
JimKshortstep4x4
Re: Removing ignition?
If you have not removed the lock cylinder, the bezel will not come all the way off. (To remove the lock cylinder, turn the ignition switch to the left, insert wire into small hole to release cylinder and turn further left. The cylinder can then be removed).
The bezel can be removed once the lock cylinder is out.
Jim
Old 12-27-2005, 01:34 PM   #3
muddpile
muddpile's Avatar
OK, so I stick the key in, turn the ignition to where accessory power would normally be on the left, stick a wire in that little hole in the front on the edge of the cylinder, turn the key further left and pull it out? I'll have to try that. The little hole is the one on the front correct?
Old 12-27-2005, 04:01 PM   #4
Putter
More Cowbell....
Putter's Avatar
Yep. I ended up using the smallest precision screwdriver I had in the hole (it was stiffer than a wire)...you know....the eye-glasses type of screwdriver.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 12-27-2005, 04:31 PM   #5
MDC
MDC's Avatar
I always use a paperclip
67 C10 Shortbed 327
05 F150 4x4 NO APPOLOGIES 's
02 Xpress X19 02 Yamaha VMax 150
www.xpressboats.com
Nothing says 'poor craftmanship' like wrinkles in your duct tape
MDC is offline   Reply With Quote
Old 12-27-2005, 04:35 PM   #6
6T8
Active Member
Any options if you don't have key? Thanks for any info.
6T8 is offline   Reply With Quote
Old 12-27-2005, 04:38 PM   #7
Putter
More Cowbell....
Putter's Avatar
Drill bit!!!! If you don't have a key, I think you are pretty much screwed.
Use the bezel tool (for removing the ring) and just unscrew it....it will snap the face off the cylinder....or at least mine did.
Old 12-28-2005, 12:41 AM   #8
muddpile
muddpile's Avatar
Got it out! Found a scrap of wire on the floor of the truck that worked great. Thanks everyone!
Old 12-28-2005, 05:45 PM   #9
72swb4me
72swb4me's Avatar
I don't have the key for my truck, so what do I need to do take my existing switch off?
72swb4me is offline   Reply With Quote
Old 12-28-2005, 05:54 PM   #10
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I used a sawzall on mine that did not have a key. It ruins the whole unit but at least it is out.
chevyguy_72 is offline   Reply With Quote
