Old 12-27-2005, 12:31 PM   #1
zipgun
ZIPGUN
zipgun's Avatar
Question Oil Pressure switch/sensor common problem?
OK so I got in my 90 4wd burb and drove 13 hours yesterday from King, NC to Memphis, TN. Engine ran awesome, 17 MPG ran like a top. Get here and my oil pressure sensor is showing low. No lights just the gauge. No valve train noise, runs like new. Is the oil pressure switch a common or semi common fault on the 5.7 - 350 ? I am thinking its just the gauge itself and have been told this by others here, just want to run this by you guys.
zipgun is offline   Reply With Quote
Old 12-27-2005, 11:25 PM   #2
wink_tim
wink_tim's Avatar
Re: Oil Pressure switch/sensor common problem?
Yes it is a common problem, I changed the sending unit on a freinds 89 K-5 a couple of weeks ago. It was showing 0 oil pressure at idle but works perfect now. It was kind of hard to get to, I ended up just pulling the distributor to make it easy. The part was like $25.
67 SWB
wink_tim is offline   Reply With Quote
Old 12-28-2005, 12:39 PM   #3
zipgun
ZIPGUN
zipgun's Avatar
Thanks Wink Tim I appreciatte it, pulled the distributor huh ? Yikes I think I'll get to this when I am back in NC. Thanks for the input!
Zipgun
Old 12-28-2005, 04:17 PM   #4
1976K5CHALET
1976K5CHALET's Avatar
It can be a pain to change because a 90 has one switch behind the dist...get a set of obstruction wrenches from harbor freight on the cheap and you won't have to pull the dist. 17mpg...must be a half ton with a R4 as our V2500 gets 11-12mpg with a TH400...lol.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 12-30-2005, 01:07 PM   #5
zipgun
ZIPGUN
zipgun's Avatar
DW
I love harbor freight and northern luckily we have both those store within an hour here in NC. For the MPG - I think the Cold air system from airaid and the Helix TBI spacer helped quite a bit!! Thanks for the info !!
Steve
Old 01-04-2006, 02:42 PM   #6
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Thanks Wink Tim for the oil pressure gauge info. I bought an 87 4x2 last year and it has been showing 0 pressure since I bought it, so now I'm sure its the sender and thanks to you I know where it is on the motor.
Hey ZipGun do you have the Helix Power Tower spacer on your Burb? I did some surfing after I seen this thread and found one at performanceproducts.com for 59.95, does that price sound about right to you? I also found the Airaid intake system for 139.00.. I have an 87 4x2 with 3:08's in the rear. If you get 17mpg with your 4x4 ( which probably has 3:42's or 3:73's ) and the extra weigh of a 4X4 I figure I should be up around 20MPG if I do theses changes to mine, what do you think? Where did you get your parts from?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 01-05-2006, 01:28 PM   #7
zipgun
ZIPGUN
zipgun's Avatar
Those prices and parts are correct, they definitely helped improve the performance of my burb. Helix and Airaid are the same companies I purchased from.
