12-27-2005, 02:47 PM | #1 |
Transmissions
What are the 5 speed manual transmission names for full size chevy pickups that fit the 73-87 pickups?
Any 6 speeds ever made? Thanks
tblough I love my Truck! '84 Custom Deluxe C10 LWB Inline 6 250ci 4.1L 2wd |
12-27-2005, 03:00 PM | #2 |
Re: Transmissions
i know that the manual trans that came on the 1/2 ton models were 4 speed's. these 4 speeds were really 3 speeds due to the "high" creaper gear. i have seen some trucks here with 4, 5, and even 6 speeds but more often than not they require crossmember mods and deep pockets
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
12-28-2005, 01:58 AM | #3 | |
Web Wheeler
Re: Transmissions
From what I've seen, many 1/2-tons came with the heavier duty SM465 trans.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
12-28-2005, 11:15 AM | #4 |
Re: Transmissions
I actually have a nv3500 in my 87. It came out of a 94 1/2 ton. Still trying to find a cheap way to get the speedo to hook up.
Guess I'll eventually go to aftermarket guages, but I'm still looking for the harness that goes to the tranny.
87 Shortwide Silverado nv2500 5-speed |
12-28-2005, 01:10 PM | #5 |
Re: Transmissions
so what are the name (i.e. NV5600) that were used in the early 80's till 87? I won't have the time or money to change the speedometer.
12-28-2005, 12:06 AM | #6 |
Professional Grade
Re: Transmissions
The 5 speeds that are most commonly installed are the NV4500 and the NV3500
The NV4500 is the more expensive transmission. The early Chevy version of the NV4500 have a very low first gear like the SM465 4speeds that were found in the older Chevy trucks, then 3 "normal" gears, and a 5th overdrive gear. The later Chevy and Dodge NV4500s have a higher 1st gear, then the same 3 "normal" gears and a 5th overdrive. These transmissions are very tough, and are found in the early 90's 3/4 and 1 ton trucks. NV3500 is found in both the C/K 1/2 tons, and the S series trucks. They have 4 "normal" gears, and a 5th overdrive. They are far cheaper than the NV4500 (which typically runs about 1200 - 1500), and far more common to find as well. Only problem is that they are not built tough enough to withstand any real abuse. They will last ok if you drive them nice, but if you like to bang through the gears, and drop the clutch often, you'll want the NV4500. Of course, there always is the NV5600 (6 speed truck transmission, totally bullet proof) too, and a whole lotta car trannies (T-56 6 speed, etc) that you can install, but they get rather expensive real quick!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
