Vintage Evil
matching up discs and pads
I am working on getting my 4 wheel disc stuff rounded up. I had a quick question. Is there somewhere if can order rotors and pads that match
(for example: 72 chevy stock front discs and pads then rear one implanted from a camaro or caddy with impala rotors.) Thanks |
Vintage Evil
Re: matching up discs and pads
so out of all you guys with 4 wheel discs no one has the same style of rotors and pads front and back?
![]() Join Date: Feb 2004
I have 83 camaro rotors on back of my 67 that use the 88 S10 pads with 88 front 4wd L/D rotors. I am a six lugger.
Are you asking where you can order the parts from the same place, or if you can say use front and rear 94-5 Impala brakes on a 71 C10?
If it's the latter, it's not the easiest to do. I've been doing a fair bit of research. If it's the former, then it's a breeze. Buy the pads for your caliper type then your rear rotors that match your bolt pattern (most rear rotors are the same thickness, from what I've found). |
#5 | |
Vintage Evil
#6 | |
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA%3AIT&rd=1 Calipers can be painted. Autozone is your friend there. Pads have a lifetime warranty there, as well. I am doing the same thing, there. Matching pads, calipers and drilled/slotted rotors. Last edited by FormerMember; 12-28-2005 at 10:40 AM. |
#7 | |
Vintage Evil
If you look in that guy's store, he has matching front rotors. Or he did, when I was last looking. Might want to contact him.
Or you could spend a boatload of money at Summit:
http://store.summitracing.com/defaul...=egnsearch.asp For a 69-80 Chevy C10. http://store.summitracing.com/partde...6&autoview=sku 96 Caprice rear. Those are singles! To make it more clear, looks like you can open the range up on the front rotors. Summit says 69-80 are a bolt on. I am sure there are more. Last edited by FormerMember; 12-28-2005 at 10:55 AM. |
#10 | |
Did you redrill them? Last edited by FormerMember; 12-28-2005 at 10:57 AM. |
