Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 12-27-2005, 05:40 PM   #1
smokinn
smokinn's Avatar
WTB np205 and other parts
Ok what I really need is the rear drive shaft for a np205 transfer case. That will fit a 77 SB 350 4x4 with a 350 tranny. I have everything else just need the rear drive shaft.
Jason
smokinn is offline   Reply With Quote
Old 12-27-2005, 08:38 PM   #2
bisquik65
bisquik65's Avatar
Re: WTB np205 and other parts
Do you have a bolt on yoke...on the case or slip yoke...And a th350/205 is a rare setup...
Also a weld to weld measurment would help too
bisquik65 is offline   Reply With Quote
Old 12-27-2005, 08:53 PM   #3
smokinn
smokinn's Avatar
Originally Posted by bisquik65
is a rare setup...
Why is it rare? A 205 is a pt transfer case. A 203 is a full time transfer case. Thats whats in it now is a 203. I want to get rid of the FT and put in PT. I know they make a conversion kit for the FT to PT. Has to do with swapping gears but I dont think its a good route. Cheaper but I cant see how it can be better.
Jason
Old 12-27-2005, 08:58 PM   #4
bisquik65
bisquik65's Avatar
Jason
You may want to go to the faq's section on the board...over this swap...It is not a direct bolt on....Or try the 4x4 discussion...board.. And the adapters are different,mounts are different...Just trying to help,Thanks,Erick
Old 12-27-2005, 09:58 PM   #5
smokinn
smokinn's Avatar
Eric,
I know your trying to help as this swap is new to me. Do you think the conversion kit would be a better route?
Jason
Old 12-27-2005, 10:22 PM   #6
67-72williso
Junk/Daily Driver Club
67-72williso's Avatar
Putting lockouts on the hubs will help. NP-203 trucks didn`t have lockouts on the front, so the front drive shaft turned all the time (full time). Hope this helps.
Later Willis
Daily Driver: 1970 C-20 400 sbc,sm-465,Dana 61 one ton SRW rear, 3.07 gears, locker.
There are three kinds of people: those who make things happen, those who watch things happen, and those who have no idea what happened!
67-72williso is offline   Reply With Quote
Old 12-28-2005, 10:15 AM   #7
53burb
53burb's Avatar
The 203 is a chain driven case and the 205 is a gear driven case. The 205 is much stronger than the 203. The 205 is considered one of the strongest stock cases there are. Most of the hard-core 4-wheelers use the 205, especially if you plan on using 35" or larger tires and more than the average 4-wheeling.
53burb is offline   Reply With Quote
Old 12-29-2005, 05:23 AM   #8
4bynut
4bynut's Avatar
Best thing to do is get a complete setup out of another truck. The TH350 you have in front of your 203 has a different out put shaft them a TH350 w/205. I have a complete setup in a 1980 blazer i'm parting. You would still need to have a driveshaft made and install a set of lockouts and you would be done. Well just my $.02. Jason
2007 Chevy 2500HD crew cab, 4x4, duramax w/Allison trans.
2001 Chevy ZR2 Ext. cab 4x4 (DD)
1967 Chevy SWB 4x4, BBC, Th400, NP205, 6" lift, and 35's (In Process)
1970 Chevy Blazer 4x4, BBC, TH400, NP241, 6" lift, and 38.5 boggers in front, 44 boggers on the rear ( mud racer project)
4bynut is offline   Reply With Quote
Old 01-03-2006, 08:34 PM   #9
T_Dilley
Can't tell me nothin'
T_Dilley's Avatar
Whats the length on the driveshaft?
T_Dilley is offline   Reply With Quote
