True Addiction
Going low, Front end?
Hey guys,
Well I am new to the site and have just recently started on a new project. I was hopeing that someone could give me some tips on how to drop the front of my 70 c-10. I am thinking drop spindles, bags, and maybe some new control arms (possible a dropped crossmember)? If anyone could help in telling me who they think makes the best product and where I can get a descent deal on it. Also I am looking to run the biggest wheel possible, that will probably make a difference. Thanks! |
Epoxy Primer Friendly
Re: Going low, Front end?
Depends on what you wanna do with the setup... Hop, drag, or just cruise low.
Airbags Bag Brackets 2.5" Drop Spindles Summit sells 3" drop spindles also Now go spend some money ![]() |
True Addiction
One other thing, I am hopeing to run a 22x10" wheel. I was wondering what, if any front track widths would be changed by after market spindles, and control arms. I think I want it to be stock or maybe narrower to allow room for the wider wheel. Also, I want to make sure that I am able to use an aftermarket rotor and caliber in 5 lug. Thanks
#4 | |
Son Of Gravel Man
What ya gonna run on the front?
Daily driven 70 C10 longbed Its a work in progress ![]() Quote:
True Addiction
Would be great if someone could post pic's of different front end suspension. Maybe some with dropped x-memebers, or Z'd frames? Thanks. Also, how do you post pictures inside your reply's? Thanks again.
BK Built
check out my site at www.cardomain.com/id/badpanl ive got quite a few pics of me z-ing my frame... 4", not the usual 2". Fathead_03@hotmail.com is my e-mail if you have questions, or pm me on here.
True Addiction
Well, I'm planning on ordering the strong arms from Air Ride, the early classic 5-lug conversion disc brake kit w/2.5" drop spindle, Slam RE7 bags this Monday. Anyone want on here tell me why I shouldn't do this? I hope all of these will work with one another and although alittle pricey, it all seems to be high quality. Any suggestion?
The main thing you acomplish with a low front end is you look cool, in the parking lot and slow cruising way low is where its at, however while on the highway going 50-80 MPH you want to be safe not cool.With a stock camaro clip and air ride bags I can drop my truck so the bumper is 1 inch off the ground, thats as close to the ground as I want my truck to be if an air bag fails and I unexpectly drop down while going 50-80 MPH. Just a 1in dropped spindel would put me in the danger area. Now if you want too lay frame and throw sparks thats a different story, in that case looks come first kinda makes me think of a good jackass video.
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
True Addiction
Hart Rob, Thanks for the great pictures, is there anything that you would have done differently if you were doing it again? I just want to cover everything before I order all the parts. Thanks for the help again.
#11 | |
I probably wouldn't have done the dropped spindles. They're really not needed. The front tires usually hit the inner fenders or the lower control arm lays on the ground. I think it would do this without the spindles. If you are trying to lay rockers, you will probably have to do a cross member modification and remove your inner fenders. I would also relocate the lower shock mount to the top of the lower a-arm. As sent by ART, it is the lowest point on the front end and is easy to drag. If wanting to lay rocker you will also have to do a serious step notch in the rear. I've got a bolt in c-notch from CPP and 2 inch lower blocks and the rear won't get near as low to the ground as the front. Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 02-20-2006 at 07:44 PM. |
True Addiction
Im looking to go with a drop spindle-disc brake conversion kit from either CPP or ECE. I also plan on getting some strong arms from ART. The only thing I have yet to figure out is weather I should go with a earlier than 70 or 71 and later. I've read that the 71 and later runs a larger diameter wheel bearings. This could be a plus for running big wheels. Can anyone help me out? Also whats the differeance, balljoints, and tie rod ends? Thanks for the help, I just dont want to order all this stuff and it not work together.
#13 |
True Addiction
Well, I just ordered a 5-lug drop spindle disc converstion kit from CPP. I comes with 73'-87' balljoints and tie-rod ends. Also did the upgrade for some drilled and slotted rotors, mostly for looks. I also order a step-notch from Kp and front upper plates for my slam bags, I didnt get bottom cups because I plan on running strong arms, in which the bags bolts directly to, if Im correct. I hope all this stuff works good together. Any comments?
#14 | |
Seņor Member
#15 | |
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
#16 | |
Seņor Member
Sure, if you don't mind these hurdles, it's doable. It's just that most of the other techniques discussed in this forum have become well-tested, somewhat "bolt-on" solutions. Even the Z is pretty "bolt-on" now that so many have worked through the method. Reinventing the wheel, while facilitating individualism, is sometimes lots more work to accomplish.
