Old 12-28-2005, 01:59 AM   #1
apstguy
LED King
apstguy's Avatar
Rear End Q's
I suspect my differntial cover is bent or warped, I've replaced the seal 4 times and it keeps having a small leak. (10 bolt axle) I need a new cover so what do you reccomend? I would like something with an O-ring gasket. This looks cool: http://store.summitracing.com/defaul...2&autoview=sku
I also looked at Mag-hytec's cover too but they want $230 for it!!!!!
I'm also looking at putting in a limited slip or a locker, I keep spinning my tire in the rain, it gets a little annoying. Eaton posi? Powertrax no slip? Detroit trutrac?
3.42 gears and a rear end rebuild should finish that off nicely. Any thoughts??
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 12-28-2005, 02:31 AM   #2
84 400
Sb 400 club
84 400's Avatar
Re: Rear End Q's
ahhh eaton i hear really good stuff about those. they can be pricy but i hear they are worth it
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 12-28-2005, 07:54 PM   #3
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Rear End Q's
If you don't want to pay the big bucks for an O-ring cover, then get a good aluminum cover from Summit Racing or a rear end outlet. When you install it, throw away the gasket that comes with it and use a good silicone sealer to set it. NAPA sells an awesome sealer now that is called "The Right Stuff". It is made by Permatex and it acutually adheres to an oily surface. I have changed out three rearends lately and I have put the factory covers back on two of them and an aluminum cover on the third, all are sealed well. I did clean the seling surfaces with a Brake-Kleen to help them.
piecesparts is offline   Reply With Quote
