Old 12-29-2005, 11:54 AM   #1
Austin C10
1972 C10 Cheyenne LWB
Installing Lab-Shoulder Seatbelts from Andover
I'm having trouble installing some retracting lap shoulder seat belts from Andover (thru American Classic). They came with an L-bracket for the anchor on the retracting spool. The problem is that the anchor bolt, from the old seat belt, is right under the gas tank and I can't wedge the spool up under the cutout in the gas tank and still have the spool facing up. Any suggestions in getting the spool anchored?
Thanks!
Austin C10 is offline   Reply With Quote
Old 12-29-2005, 12:42 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Re: Installing Lab-Shoulder Seatbelts from Andover
Since it's aftermarket, you may have to drill a new hole to suit your location. That's what I do.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 12-29-2005, 02:33 PM   #3
Austin C10
Since its going through the floor, do I need to put any putty in the hole that I make in order to waterproof?
Old 12-29-2005, 02:40 PM   #4
76bonanza
76bonanza's Avatar
The shoulder belts I installed the retractable spool goes by the door on the side of the seat. And the solid part with the buckle mounts behind the seat by gas tank.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 12-29-2005, 03:00 PM   #5
70c10
67-72 Addict!
70c10's Avatar
The bolt will be the same diameter of the hole. Julianos sells a nice mounting plate that is very sturdy. Here:http://www.julianos.com/anchor_plate.html
After you install you can use undercoating to help seal it and keep from rusting.
Jim
