12-29-2005, 12:59 PM | #1 |
transfer case swap
I know this has probably been ask a 100 times before but i have searched and can't find it anywhere..question is i might have a shot 203 trans case,not sure yet but if so i know where there is a good 205 out of a f**d, my truck is a 1976 k-10 with a th350 tranny,how big of a pain would that swap be or will it even work?? thanks again for any help.
12-29-2005, 02:28 PM | #2 |
Re: transfer case swap
As with many things Ford did,they made a mistake and never changed it.The quality`s there since Dana built it.But,the problem is,they put the pumpkin on the wrong side.This compounded the situation to require the transfer case to be made bass ackwards.
12-29-2005, 05:57 PM | #3 |
ok ,,thanks for all the help,,,but like you said sounds like tranny went south,,,will let you know what i find as soon as i calm down enough to work on it without shoving it off a cliff...lol
12-29-2005, 07:01 PM | #4 |
They can try ya alright.
12-30-2005, 08:04 PM | #5 |
The NP203 may not be dead. They are actually pretty strong with one real weakness. The stamped metal ring that wraps around the spider gears in the rear out-put housing has some rather small teeth. That, coupled with the fact that the shifters for these units leave a lot to be desired, can lead to failure. This ring is a simple thing to check/replace and it may be your problem.
01-01-2006, 12:19 AM | #6 |
Way are you looking for a furd transfer case (drivers drop)? If you have a GM truck you need a passenger side drop case.
01-01-2006, 04:05 PM | #7 |
thanks longhair,,will check that out
american,,i just have a f**d case laying here and was just trying to see if it would work or not. |
01-04-2006, 07:17 PM | #8 |
i have seen it done. the guy had a ford dana 60 front axle(pumpkin on wrong side) and i think he got the adapter thing from advanced adapters. the only thing that i think was a problem was the shifter didnt line up with the hole on the floor so he had to do some cutting. i can go to his house this weekend and get some pics if you need them. im not a 203 fan my swap to the 205 (from a 70 chevy blazer)was probably the best mod ive done yet.
stan
79 chevy k20 350/350/205/D44/14bFF 4.56 gears rock LWB pimer black 01 S-10 ZR2 extended cab 4.3/4L60E/233 3.73 gear 31" DICK CEPEK CRUSHERS |
