Old 12-29-2005, 10:53 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Need help or suggestions here???
I am tring to work on my 72 finally got the motor running so I have some motivation.. I am trying to get the bed all done and one color but have ran into a problem on the bed ends.. Here are a few pics what would you guys do to fix these dents I tried to pull em out with the stud gun but they are right on the body lines...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 12-29-2005, 11:12 PM   #2
Orence1
Orence1's Avatar
Re: Need help or suggestions here???
What happened with the stud gun? It looks like the dent in the top picture should come out with a copper stud. Hard to tell from the picture but is the metal apron right next to the lense pushed out? If so, use a body hammer to push it back in and try the stud gun again. I doubt if you will have much luck with the crease in the bottom picture. Just got through pushing mine out as far as I could from the inside and then welded enough metal into the low spot to build it up to level. I have used the gun a lot. Let me know if I can help.
Larry
Orence1 is offline   Reply With Quote
Old 12-29-2005, 11:38 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
THE TOP 2 DENTS WHICH ARE THE SAME THE BODYLINE WAS PUSHED INTO THE BED (I HAVE NOT TRIED A STUD GUN ON IT) Ill see if I can get better pics..
MEMBER #6377
Project "7DEUCE"
Old 12-30-2005, 01:14 AM   #4
FRENCHBLUE72
PROJECT 7DEUCE
hERE ARE A FEW MORE PICS OF THE DENTS...
MEMBER #6377
Project "7DEUCE"
Old 12-30-2005, 11:20 AM   #5
Orence1
Orence1's Avatar
French,
I would sure try the stud gun. Clean the area to bare metal. Make sure you get rid of any rust where the stud or the guns contact tips will touch. It may take several studs but I think you can work it out. Let me know if I can help.
Larry
Old 12-30-2005, 11:23 AM   #6
Orence1
Orence1's Avatar
French,
I got to looking at the pictures again. I am working on the same area on my truck right now and I have the light assembly out. Let me try a couple of things today and I'll get back to you. I might have an idea or two to go along with the stud gun.
Larry
Old 12-30-2005, 11:23 AM   #7
FRENCHBLUE72
PROJECT 7DEUCE
I am gonna get back at it today since its raing I should be able to stay in the garage and knock it out with the exception of the lower rear pannel I have an extra couple of bed sides that I may try to splice into the area.... Thanks larry I keep ya posted..
MEMBER #6377
Project "7DEUCE"
