![]() Join Date: Sep 2005
another start and stall
okay been having trouble latey alot of it it seems lol. anyway i got an 1971 checy c-10 with 307 when ever i stop the truck stalls out i adjusted the idle so that it idles about 800-875 rpms sittin in the drive way it was idlein fine but the frist trip down the road it stalled out when i pushed the clutch in and started braking just sort of putt putt dead no vac leaks i fixed all them. i'm half ready to jerk the motor out and stick another one in ther just got to make it to pay day. lord help me lol thanks in advance
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Designated A-hole!
Re: another start and stall
I swear it sounds like a vacuum leak to me, but here's a ttt for you.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
i'll go check again but i thought i had all the vac leaks fixed
Designated A-hole!
Hows your fuel filter? Have you done anything to the engine before it started doing this?
Old Skool Club
![]() Join Date: Jun 2001
Just in case it has a vacuum leak you can easily say yea, or nay, by putting your hand over the top of the carb, while it is running. If it smothers and dies, versus continuing to run, then you can say no to the vacuum leak theory.
Does it have an HEI? I had a problem that arose after changing my vacuum advance. Short version: the wiring inside the distributor which fed a signal to the pickup module, would break when I let off of the gas.....which caused the "breaker" plate to move a little bit, and just enough for that connection to break. R&R'd the HEI with a rebuilt and no problemo.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
got it figured out i had an small vac leak on back of the manfoild where the was an piece of 7/16 hose with an bolt in it. fixed that it still died got to figureing out that my 800 rpm idle was the cold idle so i warmerd it up adjusted the ilde again and well i ended up having to install an new return spring becuase mine wasn't returnin lol thanks for all the help
Designated A-hole!
Glad to hear you got it going.
