Old 07-15-2002, 02:47 AM   #1
JJ
Lurking Member
Question Where to find?
Now that I have established my 72 has an Eaton rear axle, can anyone give me an idea of where to find parts to rebuild it? I'd like to keep it if that's possible.
JJ
72 GMC 1500 350 4 Speed, stone stock baby!!!!!
72 GMC K-2500 350TPI 700R4
For those who fought for it, Freedom has a flavor the protected will never know.
JJ is offline   Reply With Quote
Old 07-15-2002, 04:56 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Somebody posted a while ago that Randy's ring and pinion had some parts. Other than that I believe it's the junkyard or buy a parts truck.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 07-15-2002, 09:19 PM   #3
Vince M
Vince M's Avatar
Can you be more specific on what your looking for..? I can pass on some info if I can find it on used spiders, axles etc. There are a few places that handle new ring and pinions. The pinion bearing is expensive if you need one. I couldn't find new axles or spiders..just used ones. That's not to say they are not out there..I just couldn't find them. I did do a lot of calling around though...
Good luck and let me know if you need what I found.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 07-16-2002, 02:43 AM   #4
JJ
Lurking Member
Vince,
What I'm looking for is one, maybe both axles, and probably replacing the ring and pinion. I was thinking as long as I was in there I'd see about rebuilding the whole thing. I was talking to a guy from the Tri-Cities area in Washington about parts, but he had no idea about the cost. I like the idea of keeping the axle I have, but I'm realistic enough to know it may not happen. I'd appreciate any information you might have on cost and parts location.
JJ
Old 07-16-2002, 12:38 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Here'r the link to Randy's
http://www.ring-pinion.com/
They are up in Everett, WA.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
