Old 12-30-2005, 11:51 PM   #1
SlickSierra77
SlickSierra
SlickSierra77's Avatar
Tailgate Filler?
I was wondering where I can get the filler panel for my tailgate to smooth it out? I used to have one bookmarked but I lost the link, any help will be greatly appreciated. Thanks.
'77 GMC Sierra 2wd SWB 355SB, TH350
SlickSierra77 is offline   Reply With Quote
Old 12-31-2005, 12:11 AM   #2
piecesparts
Parts and more parts
piecesparts's Avatar
Re: Tailgate Filler?
I had mine cut to fit at a sheetmetal shop and then we stitched (welded) it into place. Sir Michaels ( www.sirmichaels.com) sells filler pieces, but the one I got for my tailgate, from them, did not fit like I wanted it to.
piecesparts is offline   Reply With Quote
Old 12-31-2005, 01:09 PM   #3
MAR-Ktech
Truck Parts Mfg.
MAR-Ktech's Avatar
Mar-K makes them for most trucks. http://www.mar-k.com/tailgate_covers___weldins.pdf Order on-line, get free freight. You can order it with or without a handle opening. There are full covers that cover top to bottom and "weld-in"s that cover the lower half of the gate. Both need to be welded.
There are probably other board members that have used Mar-K tailgate covers. Was the fit what you expected? We always appreciate feedback, especially if it helps us make a better product.
Mar-Ktech
GET MAR-K Quality!
Restoration and Custom Pickup Parts for Chevy, GMC, Ford, Dodge and Custom Trucks
MAR-Ktech is offline   Reply With Quote
Old 12-31-2005, 01:18 PM   #4
72MARIO
72MARIO's Avatar
I should say here the front bed pannel for my wood floor 67 Fleet was AWESOME. It bolted right up not one thing needed to be adjusted no hole needed to be reemed out. It actually was the only body part that only required just primer and paint and no filler.
I got it from Bills Truck Shop here in Ontario Canada.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-31-2005, 02:12 PM   #5
WLPTMP
Active Member
WLPTMP's Avatar
i have seen a smoothed tailgates from someone maybe goodmark?
do a search on google for it
WLPTMP is offline   Reply With Quote
Old 12-31-2005, 03:42 PM   #6
piecesparts
You have to appreciate a company that watches the forums for things that they can do for you. That is salesmanship at it's best, good job Mar-K.
