12-31-2005, 12:35 AM | #1 |
Broken tracking arm (pan hard bar)
Today I thought that it would be a good day to rotate the tires. While putting my truck up on jack stands, I noticed out of the corner of my eye that the tracking arm behide the rear axle, was broken off & hanging down by a single bolt. The bar shreared from the cylindrical lug at the weld, on the frame rail end of the tracking arm. The bolts are still in place.
My truck is a 68 short step daily driver & completely stock. I personally replaced the tracking arm bushings 4 years ago. The truck is always driven & loaded correctly when hauling any loads. Has anyone ever heard of these tracking arms failing? |
12-31-2005, 12:56 AM | #2 |
its all about the +6 inches
Re: Broken tracking arm (pan hard bar)
When i first got my old 69 GMC, that bar was broken. After driving that sucker liek that, i can't see how you didn't know something was terribly wrong. Mine was squirming all over the place and kinda acted like rear stear, like a fork lift.
I have no clue HOW it broke. Mine was broken in the center,a nd it was a fairly clean break. There was no bend, no signs of trama...nothing but 2 pieces of bar that used to be one. I installed a $5 junk yard piece, and never had another issue with it. |
12-31-2005, 09:08 AM | #3 |
Yes, I did notice that something got loose with the truck in the last few days. The tires are not the best, so thats why I was going to rotate them. Even though I am very much aware of the function of the tracking arm & do all the work on my truck, I never expected that bar to break. Maybe on a 4 wheel drive off road truck, but this is a 2 wheel drive street truck.
This bar failure was similar to yours, not bent.......just a clean shear. I was considering going to the wrecking yard to pick up another tracking arm. Then I was thinking that those, almost 40 year old arms maybe steel fatigued. The other option is to spend $50 bucks on a new Chineise repro. Well, as I said this is a daily driver so whatever I find first, is what is going to be bolted on. |
12-31-2005, 09:25 AM | #4 |
User #12137
i have broke the one on the 67 once have no clue what made it brake i just thought is was a old age thing got weak and snaped
12-31-2005, 09:44 AM | #5 |
I've broken a few of them. It's pretty common. They're very weak.
Check out an aftermarket one or make one yourself. I made one, using johnny joints on an old C20 I had. Sold it, I am not sure he's on the board anymore, but it was beef. I also drove that C20 without a tracking bar for a bit. Of course, I had all new trailing arm bushings, so it wasn't as bad. You may want to replace those, too. Last edited by FormerMember; 12-31-2005 at 09:45 AM. |
12-31-2005, 10:56 AM | #6 | |
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
12-31-2005, 11:28 AM | #7 |
If GM dealer still have those for $20, that sounds like the way go! Thanks.
12-31-2005, 12:29 PM | #8 |
18 Till I Die
Does anyone have a GM part No.??
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... |
12-31-2005, 08:01 PM | #9 |
Good Question!
I would rather go to the dealer with the part number, than depend on them to come up with the correct one. If no response from any board members, I will go to the dealer & let you know what I find out. |
12-31-2005, 09:02 PM | #10 |
SORRY... IT'S BEEN QUITE A WHILE & I SUFFER FROM THE DREADED C.R.S DISEASE. JOHN
12-31-2005, 09:06 PM | #11 |
member #16
Junkyardjohn got a pretty good discount or I got bent over. I have an invoice dated 12/16/96 for 3854906 rod
list $47.74 I paid 39.78 I dont get any business discount. I guess it is possible for prices to change for the good on these parts. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
01-01-2006, 09:43 AM | #12 |
Watch out for your cornhole !
You didn't get screwed John. My good buddy is a GM parts man, and he treats me right. I believe the price in near 40 dollars now for a new one with bushings and all.
01-01-2006, 02:18 PM | #13 |
Any pointers to the aftermarket products? I'm collecting parts for my rear suspension overhaul and I might as well do that "while I'm in there"
01-01-2006, 04:21 PM | #14 |
Early Classic Enterprises. No one has customer service even close to them. Look in the review section to see what many people have to say about them.
