Old 12-31-2005, 06:07 AM   #1
67chevemall
67chevemall's Avatar
playin with dashes..
A little more progress this week.
The truck came with a 3 hole dash that was great because I had to wire the whole truck,and to get everything working right it did the job. Then I switched over the cluster wiring from gmcpaul's web site to make
way for the 7 hole dash.
At first I tried a am tach witch I had mounted on the lower dash. Installed it is in the pic of the dash with the wood bezel, and by itself.
I went with the wood bezel becaue the 1980 camaro colum is to wide at the bottom. This was a whole other work order.
If I get to the show level or if some rich guy from TV would sponsor my truck then I'll probally go with a custom billet dash with the comp gauges. But for now I like to get every factory piece I can.
So I ordered a factory tach because I had the thing in and out so many times I should make a quick release harness.(shhhh)
I have it all together now. It is the pic of the wood cluster not in the truck.
I finally have it ready to goin this morning. I'll get a pic when it is in....
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 12-31-2005, 06:12 AM   #2
67chevemall
Re: playn with dashes..
new camera
Old 12-31-2005, 06:16 AM   #3
67chevemall
here are a few more....
Old 12-31-2005, 06:19 AM   #4
67chevemall
last one e for e on the pics
Old 12-31-2005, 08:04 AM   #5
Bowtie67
Bowtie67's Avatar
Nice work, I kinda like this peice and instead of the stock gauges try some Autometer or other aftermarket gauges
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 12-31-2005, 08:27 AM   #6
70GMCer
70GMCer's Avatar
Bowtie67, where did you get that aluminium dash bezel.....I never seen that before.....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 12-31-2005, 09:28 AM   #7
OLDROCK&ROLLER
OLDROCK&ROLLER's Avatar
Nice work. You should be called the "dash Master"
72 CHEYENNE 10 SUPER
468/400/3.73
OLDROCK&ROLLER is offline   Reply With Quote
Old 12-31-2005, 07:53 PM   #8
matthufham
interesting. i wish i had that many gauges, i have 3 and no garage full of extras.
matthufham is offline   Reply With Quote
Old 12-31-2005, 07:57 PM   #9
Very Nice Work!!!
Old 12-31-2005, 08:04 PM   #10
68haywagon
I'm watching you!
I like that one!
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 12-31-2005, 08:51 PM   #11
sbc421
sbc421's Avatar
Here Is Mine
This will go all the way across the front of the cab. It will replace the stock dash and glove compartment. I laid out the design on paper and then traced it into my buddy’s computer plasma cutter. The material is 3/16" aluminum. After I get all the gauges in place and fit up is complete I am going to disassemble and have the aluminum "brushed", anodized red and then powder coated with a clear coating. This whole assembly when done will end up costing me about $1800.00… but I feel it is worth it to have a one of a kind dash. If I would have had to pay for the aluminum and the fab cost to lay it out and cut it I would have to add another $200.00 bucks to the cost. The gauges are all AutoMeter Pro-Comp Super Light gauges.
1970 Model C10 LWB, Small Block 421 CID, AFR 220 Heads, 1050 Dominator, Super Victor Intake, Comp Cams Mech Roller, Comp Cams ProMagnum Roller Rockers, 13.8:1 Compression, 4500 RPM TCI Converter, TH400 TCI Transmission w/reverse manual valve body w/trans brake, 5.13 Rear Gear on a full Spool, 31-16.50-15 Mickey Thompson ET Streets
sbc421 is offline   Reply With Quote
Old 01-01-2006, 01:30 AM   #12
bskylerj
bskylerj's Avatar
Nice stuff guys. Here is what I put in. It is a covan's classic set up with Autometer gauges.
bskylerj is offline   Reply With Quote
Old 01-01-2006, 12:56 PM   #13
67chevemall
^ that is so nice!
Old 01-01-2006, 12:58 PM   #14
67chevemall
Re: Here Is Mine
That is crazy! Awsome for interior rebuilds!
If I go empty interior with a roll cage you can
cut me out one of those 4 Sure!
Old 01-01-2006, 01:03 PM   #15
67chevemall
Found the cut out on evil bay. Somebody might know
who cuts them out. Comp. Lath and your in....
These ones I'm sure now he sold on evil bay because
they are a little out.
Old 01-01-2006, 01:16 PM   #16
Bowtie67
Bowtie67's Avatar
The dash came from Javy, he is/was a member on the forum, I have this as well as I have seen a couple other board members with dash, the guages dont come with it
here is a link to his web sight
http://www.jjengineering.us/products/products.htm
2009 Toyota Tundra
Old 01-01-2006, 05:38 PM   #17
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That covans set-up looks really nice is there really as much gap between the pannel and column as it looks like???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 01-01-2006, 07:15 PM   #18
It looks like the gap is for the pointer and PRNDL1 for the column automatic. I had to look real close to see it. I thought it was weird at first.
Old 01-01-2006, 07:41 PM   #19
70c10
67-72 Addict!
70c10's Avatar
My buddy just got a call from John Covan of Covan's Classics last week. They want to use his Nova for a prototype for the 75-79 series. I like it.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-02-2006, 03:08 AM   #20
bskylerj
bskylerj's Avatar
No the gap will be gone once I finish the wiring. The steering column is not bolted in all of the way. I had the Dakota digital gauges in before and took them out as they were voltage sensitive. I unbolted the column as it mad this proccess easier. I can asure you that ugly gap will be gone soon.
Old 01-02-2006, 12:12 PM   #21
mrein3
mrein3's Avatar
Three years ago I was messing around with a stock 1971 Monte Carlo cluster. The speedo is a direct bolt in.
So if you spend a lot of time in the 100 - 120 mph range, and you want the stock look, this may be your answer. (Just buff off the truck's stock mph numbers).
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 01-02-2006, 03:52 PM   #22
67chevemall
^ cool idea. once the 3:08s are in who knows
