Old 12-31-2005, 10:03 AM   #1
willow72
willow72's Avatar
front wheel bearing torque
can somebody tell me what the torque specs are for the front wheel bearing on our trucks is ? thanks in advance, john
willow72 is offline   Reply With Quote
Old 12-31-2005, 10:11 AM   #2
Sweet72
Sweet72's Avatar
Re: front wheel bearing torque
I never torque them just rotate wheel while tightening until all slack is removed then tighten till a cotter pin can be installed. My '72 chassis service manual lists the wheel bearing preload as zero, so just take up all the slack.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 12-31-2005, 10:24 AM   #3
Sweet72
Sweet72's Avatar
In the front suspension torque specs, the Chassis Service Man. lists 15lbs. ft. C10 and 40lbs. ft. C20,30 and then back nut off to align cotter pin.
Old 12-31-2005, 04:16 PM   #4
junkyardjohn
junkyardjohn's Avatar
I USUALLY PUT THE TIRE ON, SPIN IT WHILE TIGHTENING THE SPINDLE NUT. I TIGHTEN THE NUT UNTIL THE TIRE STOPS ROTATING, & THEN BACK THE NUT OFF 1/3 - 1/2 TURN. DOING THIS MAKES SURE THE BEARINGS & RACES ARE SEATED. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 01-01-2006, 02:19 AM   #5
Jim_PA
Sounds like my proces... a little more than snug by hand, then back off to the first hole.
Jim_PA is offline   Reply With Quote
Old 01-01-2006, 06:51 AM   #6
JimKshortstep4x4
I tighten them similar to John's method. Tapered roller bearings need to run with a preload on them to keep the rollers in contact with the races. A loose tapered roller bearing can have skidding and sliding of the rollers leading to premature failure. Also any looseness in the bearings can cause wheel shake so some preload is desireable.
Jim
