Old 12-31-2005, 04:35 PM   #1
4tiresngas
An American Soldier
4tiresngas's Avatar
Question Leak around Speedo Cable Connection
I have transmiision fluid dripping from my speedo cable right where it connects to the transmission. It is a new cable. Is there an o-ring or something that I can replace where the speedo connection is on the transmission? There is a bolt and bracket holding iin a ratio gear (i assume), but the piece seems to move easily. Any ideas?
Dan
dan.brue@us.army.mil
4tiresngas is offline   Reply With Quote
Old 12-31-2005, 04:44 PM   #2
7T1BURB
Re: Leak around Speedo Cable Connection
Experienced the very same problem and it was caused by the O-Ring that had become distorted. New O-Ring installed and the problem was solved. It may well be that the O-Ring on your drive assembly is missing or distorted. Hope this helps...
7T1BURB is offline   Reply With Quote
