Old 12-31-2005, 08:52 PM   #1
longnlow72
longnlow72's Avatar
Question Lets play, Name that plug!
Today, I was looking at wiring on the firewall. Seeing what goes to what and what I could eliminate. I found a plug on the passenger side that didn't connect to anything(pic #1). Coming from the plug there was 3 wires, blue, green, and brown with a white tracer. The green wire was cut shortly after the plug and went to nothing. I then traced the blue and brown wires back to see where they went and they went in the hole with the arrow pointing at it(pic #2). In the same loom as the blue and brown wires there was one red wire and one black wire. They both were cut on the same end as the plug and went into the firewall in the same spot as the others. The red wire went to a key-on power soure on the fuse block. The black wire, along with the blue and brown went to a relay mounted above and to the right of the fuse block(pic #3). Any ideas of what these wires are for? Thanks
-Ben
72 Chevy lwb, cowl hood, shaved antenna, shaved bedrails, blazer tank, sidemarker fill, 1pc windows, flowmaster 40's, alpine deck, infinity 6x9's, infinity 4"ers, 2 jl audio 10w0's, grant wheel, keyless entry and alarm, more waiting to be done...
longnlow72 is offline   Reply With Quote
Old 12-31-2005, 09:02 PM   #2
68 short step
Re: Lets play, Name that plug!
blower motor something
68 short step is offline   Reply With Quote
Old 12-31-2005, 09:16 PM   #3
john
member #16
john's Avatar
Trucks with TCS had a solenoid on pass side of intake manifold by carb. They were controlled with a relay,but Im not sure of the location on the trucks. I think they had a connector similar to yours. John
john is offline   Reply With Quote
Old 12-31-2005, 09:28 PM   #4
68cajun
68 C/10
68cajun's Avatar
Looks like an A/C clutch plug to me
(2009) GMC Sierra Denali 6.2 AWD
(67 C/10 fleetside SWB)
(2018GMC Yukon Denali) Wifes Car
68cajun is offline   Reply With Quote
Old 12-31-2005, 09:38 PM   #5
longnlow72
longnlow72's Avatar
would that be on a non-ac truck?
Old 12-31-2005, 09:42 PM   #6
truckdude239
truckdude239's Avatar
not unless the truck had ac at one point in time
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 12-31-2005, 09:43 PM   #7
longnlow72
longnlow72's Avatar
hmmm....Any other ideas
Old 12-31-2005, 10:56 PM   #8
matthufham
i asked about this not even a month ago, turns out it's an emissions thing. one or 2 go to the carb, 1 to the trans to mess with idle or something.. mine were cut, they're gonna stay cut.
matthufham is offline   Reply With Quote
Old 12-31-2005, 11:02 PM   #9
matthufham
http://67-72chevytrucks.com/vboard/s...d.php?t=182844
found it
