Back in the sticks
Windshield wiper rebuild???
Has anyone ever had any luck rebuilding the mechanical arms for the windshield wipers? I need to do the ones for the Blazer and then want to do the truck. How do you get the splined portion off the wiper arm mount? Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Back in the sticks
Re: Windshield wiper rebuild???
ttt
Back in the sticks
Guess I'll turn this into a FAQ when done doing mine.
Back in the sticks
Well, found some things out today I didn't know before. Here is what they looked like before starting the rip out:
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 10-04-2007 at 08:37 PM. |
Back in the sticks
And the other side's:
Back in the sticks
Used a die grinder to take off the staked portion of the shaft, trying not to mess up the splines:
Back in the sticks
Then used a pulley puller to remove the splines.
Back in the sticks
Be careful with the puller tho, it will mess up the outer splines if you are not careful:
Back in the sticks
Once the outer spline part it off, it looks like this:
Back in the sticks
Here are all the parts together: The wavy washer went on the bottom under the outer portion.
Back in the sticks
Looks like the shaft is carried inside a brass bushing under the splines. Guess after its all cleaned up all I will have to do is just grease it well and reassemble. I'll post some more pics once the grit blasting and cleaning are complete. Anyone know where to get new splines? Thanks, Jeff.
Back in the sticks
Nobody has ever bought new splines? Any board vendors carry them? Thanks, Jeff.
