An American Soldier
![]() Join Date: Feb 2005
Okay, I have been trying to clean up the underside for a little while now. I finally figured out where the transmission was leaking from. It leaks from around the dip stick. I got a brand new dip stick w/ new o-ring and installed it. It still leaks there.
So, I need to figure out where to get the grommet that is actually in the transmission housing where the dip stick goes in. Anybody know where I can get a new one..preferably online, since it's 45 miles to the nearest part store. Thanks for any help.
Dan dan.brue@us.army.mil |
![]() Join Date: Sep 2005
Re: Help - another transmission leak
umm last time i had that problem i use blue rtv and gooped the o ring in it and soved my problem just neve could get the dip stick tube back out
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
I just replaced my dip stick seal (the one in the tranny). Their are 2 types, the old style (mine) is just an "O" ring. The new style is a rubber grommet. This fixed that leak however, I soon found that the shifter shaft is leaking also.
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
An American Soldier
Ron, where did you find the dip stick seal at?
its all about the +6 inches
Dan, Barstow doesn't have any parts stores?
I almost re-upped to go there. Kinda wish I did. kinda glad I didn't. ![]() |
An American Soldier
Longhorn Man, it is 35 miles to get to I-15 and then it's another 10 miles to get to the AutoZone and Kragen. I try to only go when I need several things...that's also where the closest Wal-mart (not even a Super Wal-Mart). Gas just cost too much. Believe me, I use the internet for almost everything out here.
I remember Ft Irwin road being long...but didn't remember it being that long.
I guess there isn't much on post for that kind of stuff either huh. Man, that's a 1/2 tank of gas just to get to the parts store. |
An American Soldier
Fort Irwin road is long and in disrepair...the State of California should be ashamed. Five people have died on that road just since October.
Watch out for your cornhole !
![]() Join Date: Jun 2003
Do you have an aftermarket chrome dipstick and tube?
I've never been able to keep them from leaking. Swapping in a GM factory dipstick and tube always fixes the problem.
#10 | |
Got it at the parts store for $1.00. I bought both types as I wasn't sure which seal I had. I still have the grommet seal on the shelf. If this is the type you need let me know and I'll send it to you. Ron (retired MSGT)
PROJECT 7DEUCE
![]() Join Date: Dec 2002
I just installed 2 lakr dip sticks in 2 th350 trannys one in my wheeling truck and one in my 454 th400 2wd they do recomend to use some rtv and they are great no leaks as of yet and my wheeling truck has been flopped many times since the install..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
67-72 Addict!
These are the GM part numbers for the dipstick seals in case anybody is interested:
Transmission filler tube seal (top hat later style) - 1259475 (350 turbo) Transmission filler tube seal (O-ring earlier style) - 6264902 (350 turbo)
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
#13 | |
Got the part # for the shift rod seal and the modulator? Thanks
