01-01-2006, 03:46 PM | #1 |
S-10 door seals?
Recent comments by Putter and Yukon Jack indicated that they were using S-10 seals on their trucks doors. There was also an indication that the fit was tight, making the doors hard to close.
I plan on replacing my door seals soon and wonder if the S-10 seals are a good idea. Is this a worthwhile modification? Better than aftermarket rubber?
69 GMC 3/4 ton LWB 383 TH400 Dana 60 '84 300ZX '79 Nova (for sale) |
01-01-2006, 04:30 PM | #2 |
Re: S-10 door seals?
I too am using S-10 door seals. They are tight, however getting better. I would not go back to the original seals myself. Talk about ease of installation!
Gary
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" |
01-01-2006, 06:55 PM | #3 |
What makes the S10 seals better? Chris
01-01-2006, 07:01 PM | #4 |
its all about the +6 inches
Can some one enlighten us on this?
Why? How? Pics? |
01-01-2006, 07:01 PM | #5 |
User #12137
they just slip on instead of glue and there alittle thicker i think
01-01-2006, 07:03 PM | #6 |
67-72 Addict!
I think the rubber is better. NO glue needed and easily removed for paint jobs. If you want to try them out before buying, go to a junk yard and get one off a S-10, take it home and install it on your truck and you will see for yourself. (This is only to give you a general idea of how they fit and look). I agree with 71swb4x4 about probably being too short overall.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads Last edited by 70c10; 01-01-2006 at 07:35 PM. |
01-01-2006, 07:19 PM | #7 |
Here are pictures of mine
http://67-72chevytrucks.com/vboard/s...d.php?t=122688 If you get seals from the junkyard they will probably be too short. When you order the weatherstripping they give you extra, but on our trucks it's only a couple inches.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
01-01-2006, 10:24 PM | #8 |
how hard is HARD (closing the door)? is it a good pull, or put your weight into it, or slam the poop out of it? 1 to 10, 10 being the hardest with the s10 and also with the stock weather strip
01-01-2006, 10:48 PM | #9 |
67-72 Addict!
I would say close to 10 either way.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
01-02-2006, 12:37 PM | #10 |
Cant you ajust the door so it don't close so tight?
72 Chevy short step side with 454 air and tilt. 72 nova project car 63 chevy II drag car Agency Iowa |
01-02-2006, 02:27 PM | #11 |
Captain Ed
What years? Are they all the same? I was just at my local GM dealer and I used '89 for a year (just out of thin air) and was quoted $89 per door and they were NOT cut to fit. I noticed on the other thread mentioned above, that it was noted that the S-10 wether stripping was "cut to fit". So, again, the question is: what years do we look for?
If you ain't bleedin', you ain't workin'! 1999 C3500 LS 7.4L |
01-02-2006, 05:30 PM | #12 | |
When he mentions "cut to fit" he is saying that you cut it to fit. It's not the exact length out of the box. That is GMC Paul's weatherstripping, and I am not sure if the dealers is the same.
01-02-2006, 05:55 PM | #13 |
I grabbed some seals at the junkyard off a 80ish fullsize chevy and put on my wife's '68. They work fine with no door slamming.
01-02-2006, 06:52 PM | #14 |
I bought brand new weatherstiping for an s-10 from lmc and at first they were stiff but after about a month I can close my doors with a slit push.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
01-02-2006, 08:21 PM | #15 |
Captain Ed
What do you do at the bottom? There's no lip at the bottom. Sorry if I soung ignorant but when I go this truck it had no weatherstripping at all. It was a basket case,
01-02-2006, 08:27 PM | #16 |
Keep On Truckin'
GMC Paul's sell Precision (or Precise) brand door gasket seals for the S-10s for about $50-60/pr and they work great. Yeah, they're a little stiffer than the stock glue-on gaskets but they loosen up over time. IMO they are the only way to fly. Plus, they have a lifetime warranty.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
01-02-2006, 08:29 PM | #17 | |
There's supposed to be a lip at the bottom! It is under the sill plates.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. Last edited by 71swb4x4; 01-02-2006 at 08:34 PM. |
01-02-2006, 08:37 PM | #18 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-02-2006, 08:49 PM | #19 |
Captain Ed
I want to keep water from splashing up out of the gutter, you guys are familiar with the gutter, right?
01-02-2006, 10:22 PM | #20 |
Captain Ed
Great. The PO was a friggin IDIOT! He put in new rockers (poorly) and shaved the bottom lip needed for the weather stripping. There is NOTHING under the sill plates. The lip just abruptly ends after making the turn about an inch at the bottom. Moron!
01-02-2006, 10:27 PM | #21 | |
User #12137
or do ya mean theres a big hole there ya can see though to the ground ? Last edited by tnblazerk5; 01-02-2006 at 10:28 PM. |
01-02-2006, 10:46 PM | #22 | |
Captain Ed
The PO fancied himself a body man. His "work" has caused me more time and energy than I he'd never touched the thing. I am DEFINITELY no body man, but many times I have fantasized about beating the PO to death with his welding gun. I'm sure my congregation and God would frown on that, though.
01-02-2006, 10:57 PM | #23 | |
User #12137
01-03-2006, 12:59 PM | #24 |
Post Whore
Here are the S-10 seals I'm using. Pretty sure I bought these from GMCPauls - they are listed on his site.
They fit extremely easily and there is maybe a 1/2" to 3/4" gap on the bottom where there seal ends just about meet. Mine have been installed about 3 months now and they have broken in nicely. Still need to close the door firmly, but that is fine with me. I'd do these again in a heartbeat.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 Last edited by Yukon Jack; 01-03-2006 at 12:59 PM. |
01-03-2006, 07:12 PM | #25 | |
No,I DON'T have Tourett's
I welded a piece of 1/2" X 1/2" 20 (?) guage angle where my lip had rusted away.
'72 K5 CST 350/350 Daily Driver '69 GMC3500 Camper Special CST Flatbed 396/400 Upgraded to show truck '69 GMC 2500 L6292, 3spd beater |
