01-01-2006, 05:17 PM | #1 |
GM ONLY BABY!!!
Has anyone installed twin piston calipers or braided brake lines on 67-72?
I am going to install my 2" drop spindles this spring, along with a whole new front end, ball joints, tie rod ends, idler, pitman, calipers, rotors, flex lines, etc. I am wanting to know if any or you have upgraded to a 2 or 4 piston calipers, drilled and slotted rotors, and stainless braided flex lines? What companies make such parts for our 67-72 GMC trucks? Thanks!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
01-06-2006, 06:46 PM | #2 |
True Addiction
Re: Has anyone installed twin piston calipers or braided brake lines on 67-72?
Sorry I can't offer any help, but I have the same question as you do. I am wanting to go with new drop spindles and switch to 5 lug. The problem is I don't know what brakes will work with say a drop spindle from early classic. I would like to run a set of Baer or Brimbo. If any one could through out some suggetion, I would be greatful. Thanks
01-07-2006, 12:51 AM | #3 |
do a search on Dennis Brooks, he has worked out a couple of swaps using 88 stuff on the 67-72
01-07-2006, 04:58 PM | #4 |
GM ONLY BABY!!!
I think I will also check out Master Power brakes and Stainless steel brakes as well.
01-07-2006, 06:14 PM | #5 |
Regular guy
http://www.stainlesssteelbrakes.com/
http://www.baer.com/ I have Baer on my 77. The kit came with s/s lines and 2" dropped spindles. If you already have your dropped spindles you can send them to Baer and they will machine them to work with their brake system.
'Frank' 77 Silverado 18 & 20 American CL205s Edelbrock MPFI, 700r4, Baer Brakes 9" F@rd rear, Vintage air, Bags etc etc.. |
01-13-2006, 07:19 PM | #6 |
Msgt USAF Ret
http://images.google.com/images?q=MUSKEGON+BRAKE&hl=en
They specialize in corvette brakes and twin caliper brakes
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-15-2006, 08:17 PM | #7 |
Try these guys http://www.performanceplumbing.com/BrakeFittings.html[/URL]. They sell all the fittings and line to make all your own flex lines and length you want. Good prices too. I used them to plumb all my brakes. Stainless with A.N fittings all around!
01-16-2006, 12:57 AM | #8 |
True Addiction
Does anyone know if there is a bit cheaper altenative, I want twin piston calipers, but don't want to spend quite that much. Can you make a single piston work as well? Thanks
01-25-2006, 03:35 AM | #9 |
7T7........thats about as pretty a piece of hardware as I've ever seen. I think I'd probably mount that on the wall of my office.
02-03-2006, 12:37 PM | #10 |
C10 Collector
I've got the Baer set-up on my truck. They come with McGaughy's drop spindles i beleive. If I would have known you could send them a set to machine, I would have sent some 3" dropped spondles, but you live and ya learn. By the way I'm running Baer's full kit, 1/4 front lines, 5/16 rear lines, no proportioning valve, with an 88-98 chevy booster and master cylinder. Its a bit touchy, but that mofo will stop before the dime.
