GM ONLY BABY!!!
Doing front end rebuild, will I need any bushings?
Are there any rubber bushings in the A arms of a 72 GMC 1500? I am going to purchase ball joints, tie rods, idler, pitman, anything else I will need in order to rebuild front end?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
![]() Join Date: Feb 2004
Re: Doing front end rebuild, will I need any bushings?
nice avatar -- as soon as I can stop looking at it I will type something useful. 72 has the threaded bushings and caps --- when you unleash the top ball joint --you can check for wear on the upper A-arm bushings Usually the top bushing go before the bottoms. Make sure top and bottom both take grease even if they do not feel worn.. If properly maintained--greasing with oil change, they never wear out.
