Old 01-01-2006, 09:04 PM   #1
riden2low
Oil Pressure?????
Got a small block in my truck and was driving it the other day and it started tapping and carry on, lost oil pressure. So I had it towed back home since I thought it was gone. Went to start it up today and the oil pressure is back and hasn't done much or make any noise. The oil pressure went up and down a couple of times but it acts as nothing happen. Bad oil pump, or main? Or needs to clean it out with a flush of some short?
68 Chevy short wide air cab
4/6 on the drop
327 small block
Front disc
Frame "c" sectioned
Gaylord bed cover
riden2low is offline   Reply With Quote
Old 01-01-2006, 09:34 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Oil Pressure?????
You checked the oil level?
How long since last oil chainge?
It may be a gonner, but I'd start with the simple stuff first.
Old 01-01-2006, 09:44 PM   #3
cableguy0
a lot of times when that happens its a loose pick up tube on the oil pump. it will bounce up and down while driving and destroy your bearings in the process of dropping oil pressure.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 01-01-2006, 09:47 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've seen smook clog the screen, till you shut the engine off. Once shut off, the smook will fall away from the screen and oil pressure will return. Then later, it will eventually get sucked back up and do the same thing over again.
Lots of mid 80's Ford V8's did that. Nothing says fun like laying on your back pulling oil pans either.
Old 01-01-2006, 09:48 PM   #5
dennislbrooks
dennislbrooks's Avatar
you will notice a loose tube most when stopping like at a stop sign, had a 66 GTO that did that. Is your oil filter plugged?
dennislbrooks is offline   Reply With Quote
Old 01-01-2006, 10:13 PM   #6
ed455
Captain Ed
Just replaced a motor in a company truck for the same thing. The motor was so clogged with coked up oil that the oil would build up in the top end of the motor until the pan was dry. Wait a few minutes and start it back uo ant the oil pressure was back.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
