![]() Join Date: Jul 2001
6 x9 Speaker Placement ?
Since I removed the in-cab tank and placed it under the bed, I've been considering installing a pair of 6x9's in the cab corners facing forward at somewhat of an angle just below the inside cab corner lip. Have a pair of Pioneer tri-axial's 150 watt that ought to do well there but no sure how to mount them. Was thinking of using 1/2" stranded fiber board but not sure how to secure it so that it is stable. Placing removeable metal or plastic grills over the speakers for protection would be a good thing. Want to be able to change or pull out the speakers without a lot of dis-assembly. Any one who has done this care to share some tips and info?
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
Re: 6 x9 Speaker Placement ?
good luck with that. i could only afford 5X7s and i'm now glad because there's not much room for a 6X9
Car O'Holic
where is that on your truck?
just get a set of 6x9 speaker boxes and set them in the corners. i have set of really small truck boxes i got from CHECKERS for 15$ and they sound freakin AWESOME. they sit in the corners behind me seat and i installed on 4x6 speaker up under the day in the original spot. truck sounds GREAT now.
#5 | |
#6 | |
A guy with a truck
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
walmart has them right now for like 10$ a piece (or set ?)
Thanks for the ideas on speaker placement. Will have to look into some of the smaller speaker boxes as the truck has new paint job otherwise the welded panels may have been an option. Should have thought about speaker placement a bit sooner I guess.
#9 | |
Car O'Holic
