Old 01-02-2006, 08:53 AM   #1
stepsidewanted
weird headlight problems
My headlights stopped working. The tail lights and rear side lights work, the front passenger side light and bumper light work. Neither head light nor the driver's side light or bumper light work. The dash lights work. I checked the bulbs. Any clues?
I have no experience working on my truck (1971 stepside), please help.
stepsidewanted is offline   Reply With Quote
Old 01-02-2006, 08:58 AM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Re: weird headlight problems
1st - to the board from west 10-uh-c
2nd - cant help, but there is alot of stuff in our FAQ's section that may
help out , or others will respond & chime in, HeadLights burned out ?
FAQ's - http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Big Piggy: "Goliath" 07 Kodiak C4500
Lil Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 01-02-2006, 09:00 AM   #3
70GMCer
70GMCer's Avatar
Bad ground wire or dirty/rusted light sockets. Also check your headlight switch for corrosion/dirt. Same thing happened to me a while back. Turned out to be the headlamp sockets were rusted up and not making contact. I just used a piece of sand paper to brighten up the lamp prongs, and a little screw driver to clean out the sockets of any rust.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 01-02-2006, 09:17 AM   #4
stepsidewanted
Thanks for the replies.
I know it's not the bulbs b/c I bought new ones. It just seems weird that they would both stop working at the same time. Plus the side light in the driver side fender and the turn signal light in the the bumper on the driver side don't work either. All other lights work fine, so it can't be the switch, right?
Are there different relays or fuses for each side?
Old 01-02-2006, 09:21 AM   #5
My guess would be the headlight switch since all the front is out. You can also check the wiring connection as it comes out of the firewall.
Old 01-02-2006, 10:25 AM   #6
LONGHAIR
99% of the time it will be the dimmer switch on the floor. All of the head light's power goes through there. The switch "decides" whether it goes to the high or low beams...........If the switch goes bad, it goes nowhere.
LONGHAIR is offline   Reply With Quote
Old 01-02-2006, 10:57 AM   #7
stepsidewanted
Got it! Thanks again.
It was the dimmer switch on the floor. High beams worked but low did not. I just assumed that neither worked. I removed it, cleaned the contacts and now it works.
The driver side marker light and turn signal still don't work though. I swapped bulbs with the passenger side and the passenger side works fine. Thoughts?
Old 01-02-2006, 10:59 AM   #8
smbrouss70
smbrouss70's Avatar
I just had to change my dimmer switch to get my lights working again. around $5 at autozone.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
