Old 01-02-2006, 02:11 PM   #1
farside847
farside847's Avatar
New Headlight conversion (pics)
Well, after going though the HUGE thread on new headlights and wires http://67-72chevytrucks.com/vboard/s...d.php?t=173230
I decided to upgrade my lights. They were dim, flickered a bit, and the
left one went out every so often. As always I went a bit pic happy.
Here is what I ordered from Summit. A new wire harness (AMC-509102) and
two new headlights (HLA-70477) for about $110
As you can see the harness came pre assembled with all the connectors
hooked up for me. The end with the two positive power leads goes on the
battery side.
Step one, disconnect negative bat cable (couldnt resist taking a pic)
The battery side old headlight connector plugs into the harness, then there
is a new connector for the headlight. This gives the signal to the relays to
turn on the lights without drawing a ton of power. On my truck it was really
tight due to the charcole filter in the way so I couldnt get a pic. Hell, I could
barely get my hand in there.
The excess wire got tucked in under the battery and the wires that go
to the other side went under the battery too.
I started at the battery end first and mounted the relays next to the
little power junction. I also attached the two positive leads to the junction
too instead of directly to the battery. If I hooked it to the battery the
connectors would have made the connection all crappy.
I routed the wire under the radiator and attached it to the top of the
frame support so nothing could get to it if I run over something. It was
a pretty tight fit - just barely long enough. I thought about running it
over the radiator instead, but I thought it would look better tucked away.
Thats it really. You also need to ground each headlight too, and install the
new bulbs just like normal. Now my head lights are brighter and steady. No
more flickering! And its much nicer driving on the freeway at night.
cheers!
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-02-2006, 05:22 PM   #2
Striker169
Car O'Holic
Striker169's Avatar
Re: New Headlight conversion (pics)
NiCe now we juST need Some PiCS of iT aT NIGHT
Striker169 is offline   Reply With Quote
Old 01-03-2006, 01:28 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Looks nice and straightforward. I haven't added relays yet but did upgrade my headlights when I was redoing my truck. Just the new headlights is a major improvement.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-03-2006, 01:39 PM   #4
BigSky71
LAIDOUT
BigSky71's Avatar
Thanks Farside, much appreciated!
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 01-05-2006, 11:35 AM   #5
Hook'em
Hook'em's Avatar
Does that harness also hook to the front running lights?
Hook'em
Hook'em is offline   Reply With Quote
Old 01-05-2006, 11:45 AM   #6
shifty
Questionable
shifty's Avatar
Sweet! Did it come with the relays and bracket also?
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-05-2006, 12:01 PM   #7
68haywagon
I'm watching you!
Looks good!!!
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 01-05-2006, 12:08 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Which headlights did you go with?
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-05-2006, 12:38 PM   #9
farside847
farside847's Avatar
No, just the two headlights.
Old 01-05-2006, 12:39 PM   #10
farside847
farside847's Avatar
Yep! came with both relays and the little metal bracket thingie.
Old 01-05-2006, 03:17 PM   #11
Lemield
Lemield's Avatar
I upgraded mine this weekend....but...I didn't like the yellow sleeve on the harness so I carefully cut it off and then was able to tuck the harness into the stock harness cover that is mounted to the radiator core support. Looks nice.
Hey Farside847...I do like that bracket though....very slick.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 01-05-2006, 04:48 PM   #12
mocwon
Keep On Truckin'
mocwon's Avatar
I bought the same wiring harness from LMC. It works great and eliminates all the soldering and shrink wrapping of wires for a build-it yourself system, plus it's plug-n-play with headlight harness.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 01-06-2006, 02:26 PM   #13
Lemield
Lemield's Avatar
I should have mentioned that I bought mine from LMC too.....no cool bracket for the relays but the same bright yellow sleeve.
Larry
Old 01-06-2006, 04:08 PM   #14
MrC1
Dork For Days
MrC1's Avatar
Very nice!
So, who has the best deal on this setup, including shipping, etc.? Summit? LMC? Other?
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 01-06-2006, 09:56 PM   #15
lloyd k
lloyd k's Avatar
nice upgrade, thanks for sharing
67 swb gmc,big block cadillac powered,400 turbo,2.73 ratio and disc brakes-basically a frankenstein of many parts-
lloyd k is offline   Reply With Quote
Old 01-07-2006, 12:54 AM   #16
wibilly
wibilly's Avatar
i to would like to make this improvement but i don't like that yellow jacket either
common sense isn't so common anymore
wibilly is offline   Reply With Quote
