01-03-2006, 12:29 AM | #1 |
Junior Member
bbc or sbc???
I have quite a dilema on my hands, not sure what engine combo to go with. My goal is to have a low 11 second truck. I have a 454 and a 350. I have talked to two engine builders and they have different opinions. One is to build a 496 with about 650hp. The other shop recommended a 383 with about 550hp. They said the weight of the bb would make it even harder to hook than it already is. I don't want to regret not going with the bb.
Either engine would have aluminum heads and forged internals. Any opinions would be appreciated. |
01-03-2006, 12:43 AM | #2 |
Re: bbc or sbc???
i hate it when people talk about the weight of a big block, yeah it does weigh more, for some reason 75 pounds is in my head, but the sound of a bb and the power they can produce is awesome... maybe im just a bb person!
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
01-03-2006, 12:55 AM | #3 |
Re: bbc or sbc???
http://67-72chevytrucks.com/vboard/s...d.php?t=184269
Here is a link to a post with pics of my truck with a steel headed big block, looks as though it hooks fine. My new motor and parts will take another 100lbs. minimum off the front. I did cheat a bit and have a 4-link in the rear, but I've seen lots of stock rears do the same, also check out my motor specs, BB all the way for my vote.
Speed is just a matter of money, question is how fast can you afford to go? 8.95@148.97mph all motor haven't tried bottle yet Sponsored by: Getz Oilfield Consulting Hard Candy Customs |
01-03-2006, 01:20 AM | #4 | |
Junior Member
Re: bbc or sbc???
01-03-2006, 01:29 AM | #5 | |
Junior Member
Re: bbc or sbc???
those were my thoughts also, all that tourqe |
01-03-2006, 01:33 AM | #6 |
Re: bbc or sbc???
You need to go with the BIG BLOCK. I have a 71 SWB with a built 454 and a supercharger. The 20's have a hard time hooking but the 15" mickey thompson street slicks hook just fine. Maybe I am just predujious since I have a big block. Nothing sounds better than a big block.
01-03-2006, 01:40 AM | #7 | |
Junior Member
Re: bbc or sbc???
sounds like you cant go wrong with a bb. |
01-03-2006, 02:21 AM | #8 |
Re: bbc or sbc???
Sure you can build a small block with big block balls, but if you put the same work and $$ into a BB (asuming you already have both engines) it's game-over. The 396 in my Sub is a small BB, but it feels/sounds so much better than any 350 I've owned... and it's in the heaviest vehical I've owned.
01-03-2006, 02:28 AM | #9 |
Re: bbc or sbc???
The 20's are sweet for the shows and to just cruise around with but when you want to play and hook I just throw on the 15" rally's with the street slicks and go. It is sweet to be going 25 to 30 and mash the throttle and it breaks loose. That is what happens with my 20's.
01-03-2006, 01:09 PM | #10 |
Senior Moment
Re: bbc or sbc???
I have always had a small block and then decided to build a BIG BLOCK
I'll never go back, Its even easier to work on
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
01-03-2006, 01:22 PM | #11 |
Re: bbc or sbc???
pv68 - care to post some pictures of your truck with the boyds on.
What all would I need to put a 454/th400 in my 70 that now has a 350/th 350 in it? Can I use the distributor from my small block for it? What do I do about the motor mounts?
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
01-03-2006, 07:10 PM | #12 | |
Junior Member
Re: bbc or sbc???
01-03-2006, 07:12 PM | #13 |
Project92 SWB stepside
Re: bbc or sbc???
Go Big Block and never look back.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
01-03-2006, 07:21 PM | #14 |
Re: bbc or sbc???
Ok, for my 2 cents worth. I put a Big Block in my '66 Biscayne with a 4spd. Until you have a Big Block you will never know. It's harder to hook, yes. But just learn how it leaves best and you will never go back.
Yes Small Blocks can fool you. But, there is nothing like the torque of a Big Block. I'm putting a 454 in my '71 ShortFleet. Who cares if it doesn't hook well. I'll have a hell of a time practicing. |
01-03-2006, 07:33 PM | #15 | |
Junior Member
Re: bbc or sbc???
01-03-2006, 07:41 PM | #16 |
Re: bbc or sbc???
In my old car, I had an all iron 400, except alum intake. The car rode good, didn't have an ill effects. I then got my (at the time it was a 461) in with 049 iron heads. The car sat some 2-3" lower, and rode like a whale driving down the road. After the 2nd rebuild, Bowtie alum heads, alum intake, the car road like it was stock. Didn't really notice all the motor in the front, until you hit the gas, and then you better have the wheel the direction you want to go, cause it's going that way anyways. The motor was est. about 550 horse. In a maybe 3000# car, it flew. Go BBC, you won't regret it. You will have alot more motor in a BBC than the same money in a SBC.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
01-03-2006, 07:48 PM | #17 |
Re: bbc or sbc???
I better keep my nose out of that stash.
That sh*t sounds good I think it's cool to have a really fast small block........ for now.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD Last edited by 72MARIO; 01-03-2006 at 07:50 PM. |
01-03-2006, 10:57 PM | #18 |
Junior Member
Re: bbc or sbc???
Looks like it is overwhelming. RAT is the way to go. I also stopped and talked to another engine builder today and he said definitly go with a rat motor. I am going to start buying parts now.
Is anyone out there running dart 345cc heads??? Last edited by pv68; 01-03-2006 at 10:57 PM. |
01-04-2006, 01:05 AM | #19 |
Re: bbc or sbc???
Choose your heads wisely and be VERY realistic, bigger is not allways better and in the end can make your motor a real DOG, the fat lazy kind.
