Old 01-03-2006, 12:34 AM   #1
gringoloco
A guy with a truck
gringoloco's Avatar
Front disc brake ID?
I am trying to identify what brake setup is on my truck. Obviously my truck did not come with stock discs('70); a PO installed them at some point.
They are a single pot, cast iron, floating caliper, five lug. Long brake hoses up to the frame rail junction where they meet the hardline with a retainer bolted to the a-arm about halfway up.
Reason I ask, I am looking to do drop spindles and want to know what to buy so I can reuse my current brake setup.
Thanks in advance for all responses, all help appreciated.
-Chris
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-03-2006, 12:42 AM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: Front disc brake ID?
it sounds like 73-87 stuff, but its hard to tell without pics.
bagged74 is offline   Reply With Quote
Old 01-03-2006, 12:50 AM   #3
krue
Designated A-hole!
krue's Avatar
Definitely gonna need pics to keep from just w. a. g.'ing.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-03-2006, 02:41 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the quick wags... I'll bust out the digicam tomorrow at work.
-Chris
Old 01-03-2006, 10:55 AM   #5
truckdude239
truckdude239's Avatar
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-04-2006, 04:24 AM   #6
gringoloco
A guy with a truck
gringoloco's Avatar
Originally Posted by truckdude239
Ask and ye shall receive...
Excuse the filfth, each area gets cleaned/painted as I upgrade. As you can tell by the dirt, I'm just getting started. Blazer tank is in now though.
Maybe you guys can ID this rear too...
The truck used to be coils, some PO bolted on all the leaf bracketry. The rear is unknown to me, check out the welds for the old spring perches. They are not angled like a coil rear would be. Looks like a truck with a narrower leaf setup. Drums are stamped MAX. DIA. 11.24
-Chris
Old 01-04-2006, 12:52 PM   #7
Bob Moore
Front looks like 73+ to me. Brake hose to front, clamp on upper A-arm, and rounded over dust/backing plate. The 72 dust/backing plate is flared away from the rotor.
Hope this helps - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-04-2006, 11:13 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
So I should be looking for a 73-87 drop spindle?
-Chris
Old 01-04-2006, 11:16 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Yes, it's definitely 73-87 parts there.
You need 73-87 drop spindles for that application. Measure the width of the rotors though. There were thick and thin rotors. They use a different spindle. When you order the spindles, they're going to ask which rotors you have.
Old 01-04-2006, 11:17 PM   #10
Tx Firefighter
Forget I said that. I looked in your pictures again, and I can clearly see the minimum thickness spec cast into the rotors. You have the thick rotors there.
Old 01-04-2006, 11:53 PM   #11
Bob Moore
I recommend ECE spindles - either from a vender or direct. Just like TexasFirefighter said use the 73-87 thick rotor not the light duty.
Good luck - Bob
vac, 454, T400
more to follow
Old 01-05-2006, 01:55 AM   #12
gringoloco
A guy with a truck
gringoloco's Avatar
Thanks for the help guys. I am on the prowl for drop spindles now...
-Chris
