Old 01-03-2006, 10:54 AM   #1
Baldheadednut
No dash lights??????
What is the most common cause for having no dash lights but still have tail lights?
Jason Perkins
Plainview Tx.
1979 Scottsdale SWB
Baldheadednut is offline   Reply With Quote
Old 01-03-2006, 11:26 AM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
Re: No dash lights??????
When I bought my '85 every single bulb in the dash was burnt out . Have you tried putting new bulbs in yet?
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 01-03-2006, 11:34 AM   #3
Baldheadednut
No I havent but it just seems that it would be somthig else scince they all went out at once.Unless one bulb going out would break the circuit.Im kinda leaning towards the headedlamp switch for now.
Jason Perkins
Plainview Tx.
1979 Scottsdale SWB
Old 01-03-2006, 12:56 PM   #4
zipgun
ZIPGUN
zipgun's Avatar
Had this happen on my 95 Jeep Cherokee. It was a fuse that popped. I replaced the headlight switch and then found out it was just a fuse. The whole cluster wouldnt light up , had brakelights.
zipgun is offline   Reply With Quote
Old 01-03-2006, 03:45 PM   #5
Baldheadednut
95 jeep huh. yeah right. So I went to double check the fuses anyway and what do you know. I guess I missed it but it was the problem.
Thanks Zipgun.
Jason Perkins
Plainview Tx.
1979 Scottsdale SWB
Old 01-03-2006, 08:48 PM   #6
kevinr1970
I have that same problem with mine but when I replace the fuse it pops as soon as I pull on the light switch?
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
