01-03-2006, 11:09 AM | #1 |
swapping in a T-350 in a 90 Burb 4x4
I currently have a 90 Burb 1500 4x4. I want to swap in a T-350 and need to know what parts I need to do swap. It currently has a 700 R-4 w/ NP241 t-case. Will the 241 bolt up to the T-350. do I need a special adapter. Do I have to change the driveshafts? I also have an NP 208 w/ the t-350 adapter if the 241 doesn't work.
01-03-2006, 02:08 PM | #2 |
Re: swapping in a T-350 in a 90 Burb 4x4
Check with your local transmission parts supply house. I used to buy a kit that had an output shaft and spacer that made it a bolt in. Why do you want to change to a 350? You will notice a drop in fuel economy and for everything up to medium duty work the 700 will work great.
SEMA Network- Protect our Hobby! 71 C30 in pieces, starting to come together. Click here for A Place For Tennessee Truck Enthusiest To Meet |
01-03-2006, 05:02 PM | #3 |
I actually found a kit from advance adapters for $204 which includes the new tailshaft,adapter, kickdown cable and dust cover for torue converter. This kit works w/o any drive line changes.Thanks for the info.
01-14-2006, 03:52 PM | #4 |
Web Wheeler
Depends on the length of the output on the TH350 and possibly the adapter.
A 208 and 241 is a direct swap. For 81-82, a TH350/NP208 was a stock offering. So a TH350/241 is very do-able with stock parts.
'66 C10 longstep - Clifford equiped '84 C20 Suburban 6.2L - awaiting 4x4 conversion '91 V3500 Crewcab - awaiting diesel swap |
