01-03-2006, 11:52 AM | #1 |
How did you mount your newer seat?
I now have a 92 or so Chevy bench I want to install in my 71. I know the holes don't all line up. What type of bracket did you make or use to mount yours? I want it solid and as pleasing on the eyes as possible. Pics would be great.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates) 67 short step project (will get SWB from the 68) 67 Camaro, #'s matching (my wife's) 03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear |
01-03-2006, 11:54 AM | #2 |
More Cowbell....
Re: How did you mount your newer seat?
I drilled new holes in the floor where needed, and installed nice strong bolts with LARGE washers under the cab for extra thickness!!!
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
01-03-2006, 02:04 PM | #3 |
Jamie Hyneman is my twin
Putter has the plan.
It is always smarter to use fine thread bolts on seats and seatbelts.
Justin SOLD 1967 K10 Fleetside, 283, Front and Rear Posi SOLD Color Wiring Diagrams Now in High Resolution V8 and Cab and Cab and Chassis |
01-03-2006, 02:34 PM | #4 |
I set the seat flat on the floor. Marked and drilled the hole. I also used massive fender washers on the under side of the cab.
I ran the seat like that for about 3 months then I pulled it out and pie cut the seat brackets so I had a little more rake to the seat.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
