Old 01-03-2006, 07:49 PM   #1
bossrod
Bed Measurements
I need the measurement for the tailgate opening for a 72' C-10 fleet side. I have the GMC assembly manual but there are no specs to show the clearances for the gate. I want to determine the proper width prior to final assembly and welding. I would appreciate some help in getting that measurement........txs......bossrod
bossrod is offline   Reply With Quote
Old 01-04-2006, 01:10 AM   #2
72MARIO
72MARIO's Avatar
Re: Bed Measurements
I would reccomend getting the gate you plan on using and align it to fit the opening in the box.There can be a fair bit of movement that could make the gate look and fit horrible if not fit before welding. Get the fit right. Then do you 2 tacks on top of the rear sill to box side.
I would perfer not to give you the measurement that way the gate fit correctly. Hope that's not a Prick thing to say...
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-04-2006, 07:24 AM   #3
bossrod
Thanks, I figured to try it that way...
