A day should have 30 hours.
So i have a small problem with my air ride system set-up (whats new) i can't decide between plastic air line or ss hard lines... so which one is better ?? what about moisture build-up in the pipes do to temp change ??
help is greatly apprieciated Oh and by the way another quick question since we are on air ride which is a better set-up for the back a triangulated 4 link or a parellel set-up ?? thankx again |
Outlandish Trends - FL
Re: Whats Better ??? (air ride)
SS hard lines are better, and when done right they look much cleaner, but a lot more expensive and require a lot of skill to bend and flare the lines. Flexible air line is good because the average joe can do it themselves with limited knowledge, and if something does go wrong it's relatively easy to fix if you have the spare parts, especially if something happens on the road. The important thing w/ flex line is to keep it away from heat and keep it off of anything that will chafe it and cause it to burst.
-Bret 67 short-fleet sold! |
thought so i think i will with ss lines there is a place near me which sells them cheap too i believe
thankx |
