Old 01-03-2006, 09:27 PM   #1
dennislbrooks
dennislbrooks's Avatar
00-05 3/4 ton oem hitch - for hidden
1978Steven, I believe you made a good snag on the free 00-05 3/4 ton oem hitch. I have one side in place for your 71. It is in near the final position and I believe I will tack weld it up so it will be lined up with the orig side, then I will remove that side.
We measured 32" to the centers of the bottom of the rear frame rails on your 71 and it should line up behind your plate bracket completely hidden. Since we have the oem mount bolts and strengthening washers it should be as structurally sound.
dennislbrooks is offline   Reply With Quote
Old 01-04-2006, 09:23 PM   #2
dennislbrooks
Re: 00-05 3/4 ton oem hitch - for hidden
1978Steve, one side done, should have it complete probably Saturday.
Old 01-04-2006, 09:35 PM   #3
1978steven
1978steven's Avatar
Dennis you are the man....
Looks good. I think it will do its job for sure.....
Thanks for hooking it up for me.
2002 Silverado 2500HD LB7 CCSB LT
EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
2004 Tahoe LT
2006 Silverado Z71 LS
1971 Chevy C10
1978steven is offline   Reply With Quote
