Old 01-03-2006, 10:20 PM   #1
Mark B
Mark B's Avatar
Crooked frame crossmember?????
On my 1970 swb c10, there is a heavy crossmember about a foot to the rear of the axle. It is very crooked! It is a U shaped channel, open to the rear of the truck. The passenger side is 2 inches more towards the rear of the truck. The crossmember is rivited to the frame rails and does not look like it was ever tampered with. And strangly, the same crossmember has a large triangular gusset on the top/driver side/front of truck side, but no matching gusset on the passenger side.
Does anyone know if this is normal? Is there a reason for it to be crooked and have a gusset on one side only? Is your truck the same? Or was my truck built by disgruntled assemby workers?
thanks everyone
Mark
Mark B is offline   Reply With Quote
Old 01-03-2006, 10:23 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: Crooked frame crossmember?????
I'm pretty sure mine is the same.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-03-2006, 10:24 PM   #3
68haywagon
I'm watching you!
I think its like that so the track arm clears when it moves. Is this a coil spring truck?
Mike
2012 Chevrolet Silverado 1500 Z71 4WD
1993 Chevrolet C-1500 W/T - Blue - 4.3L V-6, 4 speed auto - Dad's (RIP)
1992 Chevrolet S10 - LS swap project
1968 Chevrolet C-10 longbed fleetside - sold
68haywagon is offline   Reply With Quote
Old 01-03-2006, 10:25 PM   #4
incoma
incoma's Avatar
ditto. I'm not sure why its like that. My thought when I saw it is that perhaps it offsets the panhard bar in some fashion the same way that cross braces work on a shelf or cab support frame...right Palf?
incoma is offline   Reply With Quote
Old 01-03-2006, 11:00 PM   #5
1968GMC
love my truck
1968GMC's Avatar
not only that but the blazer gaz tank that I instaled contours the tank
1968GMC is offline   Reply With Quote
Old 01-03-2006, 11:09 PM   #6
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Mine is the same way.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 01-03-2006, 11:28 PM   #7
matthufham
mine's the same, i actually asked about this a long time ago and had pictures.
matthufham is offline   Reply With Quote
Old 01-04-2006, 12:51 AM   #8
powdercoats
The "crooked" crossmember actually trangulates the panhard bar. If the crossmember were not triangulated (at an angle)the "side-to -side" forces of the chassis/drivetrain when the suspension is moving up or down would push the frame into a diamond (or parallelagram[sp?]) instead of a box.
At least that is my theory. I studied it for awhile and that is what I came up with.
Anyone else?
powdercoats is offline   Reply With Quote
Old 05-16-2013, 01:41 AM   #9
First c10
First c10's Avatar
Well I know this is an old post. But was looking for info on this issue attached ia a picture of the cross member. I never noticed it till I took the bed off to cut the rear bed support in front of the rear shackle. So why is it riveted this way anyone?
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 05-16-2013, 10:06 PM   #10
First c10
First c10's Avatar
Anyone?
GO GO!!!
Old 05-16-2013, 10:40 PM   #11
crazy longhorn
Fabricate till you "puke"
Anyone else?
My thoughts are the same The 1st time I saw it(30 some yrs ago), I thought the frame was bent GM built it that way for a purpose, & I believe it was as you stated, the panhard bar mounts to the LH side of the frame, & the member is angled to effectively stiffen the rear part of the frame on the side forces. For the guys with a leaf spring truck, asking the same question....understand that the same frame was used (leaf or coil). CrazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 05-16-2013, 11:12 PM   #12
First c10
First c10's Avatar
So the angle of the crossmember is the same whether it a coil with a pan hard bar or leafs?
GO GO!!!
Old 05-16-2013, 11:54 PM   #13
Spoof
Spoof's Avatar
This was the very first question I asked on this forum 14 years or so back (IIRC) No need to worry, there all the same.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 05-17-2013, 07:24 AM   #14
It was hard to find an honest crossmember back then
