Old 01-03-2006, 11:16 PM   #1
truckdude239
truckdude239's Avatar
park lights
okay well was noticing today that my driver park light and the park light on the driver front fender don't work change dthe bulbs nothing turn singals works i did notice that when you turn the headlights on that the left turn signal in the dash lights up meaning i got an short to ground somewhere what is the best place to look all other park lights and and all turn lights work just the 2 park lights on the driver front don't thanks in advance
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-04-2006, 08:06 AM   #2
truckdude239
Re: park lights
ttt
David fuller
2000 Tahoe 5.3l 378
Old 01-04-2006, 11:56 AM   #3
sdkid
Re: park lights
Probably a bulb.
I think the world needs a drink...
Help somebody...If you can....VanZant
We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men.
Tracy Byrd
Member# 13924
'70 c10, 350/350
'68 c10 250/4spd
'68 c10 no eng/trans fac ps/pb/ac/at
(future father/sons project)
'48 Chevy Loadmaster
sdkid is offline   Reply With Quote
Old 01-04-2006, 12:00 PM   #4
truckdude239
Re: park lights
nope i check the bulbs and installed new ones used a test light and there is no power at the sockets when the park lights are on
David fuller
2000 Tahoe 5.3l 378
Old 01-04-2006, 12:50 PM   #5
jhow66
jhow66's Avatar
Re: park lights
You got a ground problem. One of your parking lights in bumper is not grounded good.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-04-2006, 03:07 PM   #6
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Re: park lights
Lost your ground and its back feeding though your signal indicator.Clean your bulb connections and socket mountings.
sneakysnake is offline   Reply With Quote
Old 01-05-2006, 09:23 PM   #7
truckdude239
Re: park lights
went out this moring removed the park light in the bumper sanded it down till it was shiny metal i also sanded the bumper where the light touches still no luck the light on the fender and the one in the bumper still down work (drivers front yet i got turn signals so ttt any other ideas?
David fuller
2000 Tahoe 5.3l 378
Old 01-05-2006, 09:48 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: park lights
if the turn signal works, then the ground is OK. It takes more amps to run the turn signal than the parking light. So the bad ground thing is 99% likely to NOT be the problem. (talking the parking lamp, not the side marker)
I do suspect the problem is related. I would first double check the bulbs again.... just swap them both left for right... just to make sure. Then, after that, i'd start looking in the harness. Esp where the side marker and the parking light go into the harness together... I'm kinda expecting you to find a problem right there.
Old 01-05-2006, 09:50 PM   #9
truckdude239
Re: park lights
i switched the bulbs and still didn't work i cut the wires where they came together and recrimped them together still nothing on the park lights didd all that the other day
David fuller
2000 Tahoe 5.3l 378
Old 01-05-2006, 10:00 PM   #10
Longhorn Man
Re: park lights
Have you checked that wire with a test light? Keep going north from the light assembly untill you find power, then back track untill you don't have power... then you should hopefully be able to see the problem by then and repair it.
Old 01-05-2006, 10:17 PM   #11
Willy Prost
Re: park lights
I had the same problem with the original park/turn signal on the driver's side. It appears that there were two problems.
1) The spring loaded base became rusted and corroded. This was keeping the lamp bulb from being held tightly in the socket.
2) The lamp socket is pressed (swedged?) onto the bucket that mounts the lens/mounts the unit to the bumper. This lampsocket wasn't loose as far as I could tell, but I take it that corrosion compromised the ground between the socket and bucket.
I replaced the park/turn signal assembly with a new repop unit. That lasted 2 years then the same problem(insert expletive here).
The solution this time was to use a turn signal/ stop light socket from a 71 Malibu. This type has a seperate ground wire and the complete socket twists into the bucket.
I had to remove the old socket and then carefully cut the resulting opening out with a dremel to make the Malibu socket fit the truck. I attached the ground wire to one of the mounting screws that hold the assembly to the bumper.
That seems to have fixed the problem. An Added bonus is that now I don't have to remove the lens to get the lamp bulb out. It justs twists and remove from the rear of the assembly.
Willy Prost is offline   Reply With Quote
