![]() Join Date: Sep 2005
buildin an 350
me and my buddy are building an 350 using an federal mogul kit this is what it inculdes
Brand: Federal Mogul Product Line: Federal Mogul Engine Rebuild Kits Pistons Included: Yes Piston Material: Hypereutectic aluminum Piston Style: Flat Piston Rings Included: Yes Piston and Ring Oversize (in): Stock Piston and Ring Oversize (mm): Stock Rod Bearings Included: Yes Rod Bearing Undersize (in): Stock Rod Bearing Undersize (mm): Stock Main Bearings Included: Yes Main Bearing Undersize (in): Stock Main Bearing Undersize (mm): Stock Cam Bearings Included: Yes Gaskets Included: Yes Oil Pump Included: Yes Oil Pump Volume: High volume Oil Pump Drive Shaft Included: No Freeze Plugs Included: Yes Camshaft Included: No Lifters Included: No Timing Chain and Gears Included: No Assembly Lubricant Included: Yes Plastigauge Included: Yes Quantity: Sold as a kit. Notes: Approximate compression ratio 9.35:1 with a 64cc head. Engine Rebuild, Hypereutectic Flat, 4.000 in. Bore, Std. Rod, Std. Main, Chevy, 350, plan on buying an new rodchester for an temp carb till i can get an better one looking at an edelbrock preformer carb 600 cfm with electric choke motor is going to be painted brigte chevy orange so far my total cost is looking at 1,424.73 if i have to bore the block i am looking at boring it .20 over what do you think the hp on this would be?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
Keepin an eye out
Re: buildin an 350
Sounds good
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
Re: buildin an 350
You will have 353 cubic inches, with a stock crank.
Re: buildin an 350
what i looking at is the block is out of an 1986 k10 4x4 so the alterantor is going to be reloacted to the passager side i don't think this will be very hard what is involded in it?
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: buildin an 350
If I understand the first post, you're at 1400 plus dollars for this buildup. You'd be easier and cheaper to buy a new 4 bolt main 350 crate engine for 1300 dollars with a warranty.
BTW, the compression specs listed are for 64cc heads, the 86 model core you have will have 76 cc heads, so bank on a lower compression ratio. You can't bore the engine till you get your pistons in hand. First, your machinist will evaluate your block to determine what oversize you'll need to bore too. Then, you have to get the pistons for that oversize. Your machinist will want to mic the new pistons so he gets the bore dimensions in proper tolerances. Never trust a machinist that will just bore one to 4.020 or whatever you ask for without already having the new pistons in hand.
Re: buildin an 350
thanks tx i plan on having the cyilders micd frist to let me know if i need to bore if i need to bored i was plaing on letting them tell me how much i need the get the kit to fitbefore i actlyy let them bore itlike you said i been looking at an new 350 crate but i want to build this thing its not going to be an stock motor just alittle more then stock
