Old 01-04-2006, 03:38 PM   #1
nowicu812
Dual port (Offenhauser) 307 ?
Has anyone used a dual port on the 307? Does it save fuel and improve low end? Was thinking about putting it on with a 1406, Headers and a 262 isky supercam. Any thoughts.
nowicu812 is offline   Reply With Quote
Old 01-04-2006, 05:03 PM   #2
nowicu812
Dual port?(Offenhauser)
Is the ofeenhauser dual port a good intake for a 307? Has anyone used one? Thanks.
Please do not make multiple posts about the same thing in different forums. Duplicates just confuse things
Old 01-04-2006, 05:59 PM   #3
Sweet72
Sweet72's Avatar
Re: Dual port?(Offenhauser)
Never heard of it 'till now looks like a high priced piece for a small motor and summit has a ship date sometime in March. At first I thought you meant the Cross Ram Dual Quad setup used on the 69 Z28. Definitely overkill. If someone gives it to you, go for it! But I'd be happy with a Edelbrock Performer RPM or Air Gap.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 01-04-2006, 07:02 PM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
those are great intakes i got one but its at bisquik65 house gettin bead blasted
tnblazerk5 is offline   Reply With Quote
Old 01-04-2006, 07:14 PM   #5
69-350
Oil trash and damn proud of it
69-350's Avatar
I agree with Sweet72. Personally, I just ordered some Edelbrock Performers, intake manifold and carburetor.... which will accompany my new Edelbrock Signature series valve covers and my new Edelbrock Pro-Flo air cleaner. Talk about going to town on Edelbrock stuff. But back to the subject here. They sound like pretty alright intakes, it all depends on what you want to spend now. Just remember some more money here, might save you more money down the road. At least it depends on the weight of your right foot. My right foot is pretty dang heavy, even with my S-10's meager 4.3L, I still push probably only 10-15mpg (and that isn't to talk about how much it costs to pay speeding tickets ) but at least it scoots around fast enough. Like said, it's up to you and how you drive. It seems like a good intake manifold for your grocery runs, or your quarter mile runs.
Mark
1997 K1500 Z71, 14 bolt SF 3.73 posi, Bright Blue Metallic. 6" Superlift
1972 C-10, toolbox, p/s, 350/TH350/3.73 open, black int., bronze
2008 Dodge MegaCab. H&S tuned 6.7 Cummins. Fast Four Tons
Some of my pics http://s107.photobucket.com/albums/m294/69-350/
69-350 is offline   Reply With Quote
Old 01-04-2006, 08:27 PM   #6
bisquik65
bisquik65's Avatar
You want OFFY power and Old school bonneville <sp? Salt flat tech. Right from the 50's and early 70's
Here is my NOS big block manifold...
bisquik65 is offline   Reply With Quote
Old 01-04-2006, 08:33 PM   #7
bisquik65
bisquik65's Avatar
Here is robb's (tnblazerk5) small block one...
And check this link out....Some cool stuff on here...Offy info...
http://www.offyparts.com/index.php?o...d492904141b80b
Old 01-04-2006, 08:39 PM   #8
bisquik65
bisquik65's Avatar
Now on your normal dual plane manifold...the left 2 barrels of the carb feed the #1 #7 #4 #6 cyl's And the right side feed the #3 #5 #2 #8 cyl's On the dual port the left 2 barrels feed all 8 cyl's and the same for the right...This = better fuel flow...And the one on my 70 LS6 454 has added i would say 75hp to the 425 it has stock... A very good manifold...
Old 01-04-2006, 08:58 PM   #9
crazy longhorn
Fabricate till you "puke"
I saw that dual port run on a 232 + .040 AMC 6.......Isky cam, Hooker 3/3 split/duals. The GREMLIN had a toploader 4spd, & an 8"rear......man did that ****er run like stink L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 01-04-2006, 09:05 PM   #10
bisquik65
bisquik65's Avatar
In the Nos box...it says on the tourque and hp...it was an average of 23% hp gain...just by adding the manifold...with a matching cam of course...Man i like them...
Old school is cool!!
Old 01-04-2006, 10:49 PM   #11
ed455
Captain Ed
Used one on a SBF and lost LOTS of power. That divider takes up a pretty large cross-section of the port. I wouldn't bend down to pick one up if it was free. Just MO.
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
Old 01-05-2006, 04:59 AM   #12
nowicu812
I already have one just never used it, I have an edelbrock perfromer too. I was just checking. I know they are on alot of big blocks around here but wasnt sure how they did on the small ones. I know new ones are high dollar (about double the performer) thats why you dont here much about them I guess. Thanks
Old 01-05-2006, 01:53 PM   #13
tnblazerk5
User #12137
tnblazerk5's Avatar
i personally would rather that the offinhouser intake and if you use the performer pm me please
Old 01-06-2006, 04:09 AM   #14
nowicu812
I was going to go against the grain and use it anyway. I was just wondering what others knew. It seams odd to me that there is just about nothing but the same advertisment Ive been reading for years on the net. I could not find one dyno test, article nothing. The only way I will know for sure is to give it a shot. If it doesnt work out I'll let you know. Witch truck are you putting yours on?
Old 01-06-2006, 04:22 AM   #15
bellafleck
aka Dlumpy the Ford guy
The offy can move alot of air and fuel more evenly but if you do not have the heads to move it or the cam it will not work
I drag race and run an offy on a ford and very pleased
bellafleck is offline   Reply With Quote
Old 01-06-2006, 06:34 AM   #16
tnblazerk5
User #12137
tnblazerk5's Avatar
the one i have now is going on the 67 with the 327 in it
if i ever find anouther one i will put it on eather the 78 blazer or the 67 1 ton
i would love to have one on everything i own
Old 01-06-2006, 09:11 AM   #17
ed455
Captain Ed
I was running a 292H Magnum and a set of well ported factory hipo heads. There were no aftermarket F*rd heads at the time. I also ran an offy 360 intake after I took the dual port off. I would bet you're not running a "dual port" on your drag car.
The reduction in intake cross-section alone makes the dual port an economy intake rather than a horsepower intake. The Offy 360 degree intakes are absolutley great and the Port-O-Sonic and Super-Sonic are my intakes of choice on Drag motors. Been there, done that.
Google "Offenhauser Dual Port" and start reading. They make good door stops and perform OK on dead stock motors which is what the were designed for. Also the work best with a spread port carb.
1999 C3500 LS 7.4L
Old 01-06-2006, 12:52 PM   #18
nowicu812
Im looking for more low end an mpg on what will end up being a mild moter, Daily driver. Planning on a 60cc or smaller 305 head. Not sure witch ones are the best for under 4 Grand driving.
