Old 01-04-2006, 08:13 PM   #1
roughedup72
roughedup72's Avatar
driveshaft center support bearing-removal
hey guys, I need to replace my center support bearing. Question is, does it need to be removed by pressing it off or should it just slide off ?
Thanks in advance for any advice.
roughedup72 is offline   Reply With Quote
Old 01-04-2006, 08:23 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: driveshaft center support bearing-removal
I replaced mine a year or so ago and didn't use a press (but I may have used a BFH, I don't remember)
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 01-04-2006, 09:27 PM   #3
Maximum Overdrive
December 21, 2012
Its easier to press it off or take it in and have the machine shop do it. You can slide them off but you do need a BFH and some elbow grease to get the job done. Much faster to let the shop take the old one off and put the new one on.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 01-04-2006, 09:40 PM   #4
355
355's Avatar
Krue, from the bearings that I have removed you DID use a bfh. I also use something that I can drift it off with. To ease your pain the next time put some Neversieze or like product on the shaft before installing the new one. I don't know if it makes a difference as far as overall balance, but I always mark both shafts to put them back in reference to how they came apart.
1969 C10 Long Step,355,700r4w/lockup, HEI,Weiand,750 Performer,1.6 rockers,Camel Humps,Comp 262Extreme,Hedman,2 1/2"pipes, tele/tilt,SunRoof,ps,Disc pb,ac,Cragar,eaton,Corvette style roll pan, Bowtie louvered tail gate,lowered 2/2.
355 is offline   Reply With Quote
Old 01-04-2006, 11:40 PM   #5
truckdude239
truckdude239's Avatar
when i replaced my transmission back at the end of novmber i replaced the ujoint and carrier bearing on the drive shaft i beat sprayed beat and beat some more i beat the bearing till it was nothing but an bearing race left and i ended p taking it to an aliment shop and paid 10 buxs to have it pressed off
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-05-2006, 10:52 AM   #6
roughedup72
thanks.
Old 01-05-2006, 11:11 AM   #7
truckdude239
and oh yeah i forgot to mark where my shafts went together haven't had any trouble yet
David fuller
2000 Tahoe 5.3l 378
Old 01-05-2006, 01:09 PM   #8
farside847
farside847's Avatar
here is the writeup when I did mine...
http://67-72chevytrucks.com/vboard/s...d.php?t=171772
1971 Chevy C10 Shortbed Stepside, 307v8 3-on-the-tree
farside847 is offline   Reply With Quote
Old 01-05-2006, 02:37 PM   #9
1971LT1SWBPOSI373
1971LT1SWBPOSI373's Avatar
Damm truckdude, you had a stubborn one. I soaked mine with penetrating oil for a few days. I had to hit it with a hammer a few times but it wasn't that bad.
1971 Shortbed 350/350 w/ Posi-traction 3:73's
1996 Chevy Silverado
TJ in Springfield, Virginia
Likes old Chevy trucks
Drinks Miller MGD
1971LT1SWBPOSI373 is offline   Reply With Quote
