Old 01-04-2006, 09:46 PM   #1
66nova383
t400 kick down assembly
I have a 69 with t4oo trans,I am in need of the kick down switch and brackets.My throttle is the type that has the rod going from peddle to the carb, not the cable type.I think the bracket and switch mount to the peddle assembly in the cab. Not on the engine side of fire wall.
Does anybody know of a vender that sells the whole assembly?
Thanks for the help
66nova383 is offline   Reply With Quote
Old 01-04-2006, 09:48 PM   #2
raidermanny
raidermanny's Avatar
Re: t400 kick down assembly
I found mine on ebay for $35. I have the cable throttle though.
raidermanny is offline   Reply With Quote
Old 01-04-2006, 10:02 PM   #3
bisquik65
bisquik65's Avatar
I have several used ones of what you need.. In my stash of goodies... .The bracket under the dash...And it has no kickdown switch...witch can be bought anywhere...aftermarket...$20 shipped to you door....I can get pics of it too. Pm me if you want one..Thanks,Erick
bisquik65 is offline   Reply With Quote
Old 01-04-2006, 10:08 PM   #4
76bonanza
76bonanza's Avatar
I used the lokar setup for the th400 kickdown sweet easy and works great.
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 01-04-2006, 11:20 PM   #5
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I think the under dash switch was for the 71-2 cable pedal assy only. The rod system should have had a kick down switch & bracket up on the carb/intake.
I can't find a pic of it mounted.
PICKMUP is offline   Reply With Quote
Old 01-04-2006, 11:47 PM   #6
Bob Moore
Pickmup shows correct. A pink wire comes from the fuse block thru the firewall with a rubber grommet to the switch and an orange wire from the switch to the trans. Takes a special ear on the carb linkage to activate(this is the hard part to find) - 15 years of junkyarding I have found only 1. The wires are usually overheated(insulation either melted or rock hard) from being too close to exhaust.
Lokar is probably the way to go.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 01-05-2006, 12:00 AM   #7
demi
demi's Avatar
Here is the complete setup you are looking for. This is off of my '69. '71/'72 were under the dash. You may be able to find the switch on ebay. Unfortunately, no repops for this stuff. There is an aftermarket switch, but it doesn't look anything like the right one.
The Lokar kit would be the best way to go if no one has one for sell.
demi is offline   Reply With Quote
Old 01-05-2006, 09:12 AM   #8
fade94
fade94's Avatar
66nova - PM sent
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
