Old 01-05-2006, 10:04 AM   #1
fade94
fade94's Avatar
Now the next step...cutting the frame...
This is my only option at this point for the following reasons.
My frame is straight, short ones I have looked at are not.
My frame is a leaf rear frame. Can't find one of these.
I want to use my entire drive train, thus the need for the leaf frame.
I have seen posts/ads for a couple of short leaf frames, but they are pricey $400+
I can cut mine and only have to get the shorter brake lines ($50). I have everything else.
Cost is the main factor here.
Only other option is to either sell my truck and TRY to find a short fleet, or trade my truck for a short fleet in the same condition of my truck, which ain't gonna happen.
68 short bed driver (71 clip on it now, swapping to 68 when weather cooperates)
67 short step project (will get SWB from the 68)
67 Camaro, #'s matching (my wife's)
03 Dodge Ram 2500 4x4 diesel 5 speed 4.10 rear
fade94 is offline   Reply With Quote
Old 01-05-2006, 10:09 AM   #2
truckdude239
truckdude239's Avatar
Re: Now the next step...cutting the frame...
hehehe
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 01-05-2006, 10:11 AM   #3
fade94
fade94's Avatar
I haven't taken the truck apart yet, just got it legal. Wanted to get it street legal so that when I cut it down, I will be able to drive it as soon as it's back together.
Old 01-05-2006, 11:59 AM   #4
72MARIO
72MARIO's Avatar
I cut my frame it's a short leaf. It's a in the but to lower but it's doable. If you plan on lowering get a coil frame. Cheeper and easy. You will also need to get your drive shaft cut down.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 01-05-2006, 12:03 PM   #5
fade94
fade94's Avatar
I will be lowering, but will do it with shackles first to see how much it changes it. I have a couple of short bed shafts in my garage so I have that handled. ECE carries a lowering leaf spring setup now as well. Once I get it shortened, I will measure to see just how low I need to go for the look I want. Probably spindles on front and springs/shackles on back.
Old 01-05-2006, 12:41 PM   #6
Frizzle Fry
Frizzle Fry's Avatar
Do it! I'm doing a '64 soon. You know, you can convert a leaf rear-end to spring. ECE sells the cradles. If you can do the frame splice you can to the rear conversion. But I understand cost and time saving. Be sure to take.post lots of pics.
Frizzle Fry is offline   Reply With Quote
Old 01-05-2006, 08:21 PM   #7
northcountry67
northcountry67's Avatar
I just finished cutting my 67 GMC frame. If you are going to do it, do it right. I've seen many of these trucks cut behind the rear cab mount and they were cut straight down. It seams like they work out alright, but I'm afraid of what might happen in an accident.
I posted a thread about a week ago called "attempting to post photos of my 67". There are a few pictures of my frame during the cutting process. I cut mine between the cab mounts where the frame is flat. I removed a 12" section using a half diamond cut. After the welding, I put a piece of plate steel behind the frame for added support. I also boxed in an 18" section where I made the cut. It is a little more work to do it this way because you will need to move the rear cab mount back 12"
As far as lowering goes, a flip kit will get you 5" out back.
northcountry67 is offline   Reply With Quote
Old 01-05-2006, 08:35 PM   #8
ratrod67
ratrod67's Avatar
Is it possible to get a short coil frame and just swap the leaf hangers onto it?
ratrod67 is offline   Reply With Quote
Old 01-05-2006, 08:40 PM   #9
gringoloco
A guy with a truck
gringoloco's Avatar
Absolutely.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 01-05-2006, 10:32 PM   #10
Eddie H.
Eddie H.'s Avatar
If anybody is interested, I know a guy here in the D/FW area who has a couple of short frames for sale. I don't know if they're coil or leaf, but I can give you his phone number if you'll email me.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 01-06-2006, 12:02 AM   #11
SCOTI
SCOTI's Avatar
PM sent.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
