01-05-2006, 12:00 PM | #1 |
Frame Differences
Can someone please tell me the differences in the frame from a 4 wheel drive and a 2 wheel drive. Can the 4 wheek drive frame be converted to a 2 wheel frame by changing the front crosss member and control arm set up? Thanks.
1986 Silverado Short box fleet side. project 2005 VW Tiguan 4 Motion 1997 Blazer S10 4x4 1990 Chevy Silverado K1500 Extended long box |
01-05-2006, 12:30 PM | #2 |
www.73-87chevytrucks.com
Re: Frame Differences
The framerails are basically the same, everything else is different. Yes one can be converted over if you have all the right parts.
Check this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=168231
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 01-05-2006 at 12:31 PM. |
01-05-2006, 01:24 PM | #3 |
Professional Grade
Far easier to just buy a good 2wd frame, and drop your 4x4's body onto it though.
2wd frames are pretty common too, so you shouldn't have any problems finding one. That 4x4 swb frame would likely pay for the 2wd frame, plus extra cash on the side!
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
01-05-2006, 01:48 PM | #4 |
I totally agree with you Russell.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
01-05-2006, 02:07 PM | #5 |
Thanks guys for the info. My problem is that I have a 2wd frame that I believe is twisted and I am picking up a 4wd truck for the box and cab. I wanted to use the frame from the 4wd for the 2wd. 2 wd frames are not commom here in Northwestern Ontario. Thnaks again
1986 Silverado Short box fleet side. project 2005 VW Tiguan 4 Motion 1997 Blazer S10 4x4 1990 Chevy Silverado K1500 Extended long box Last edited by Free88; 01-05-2006 at 02:15 PM. |
01-09-2006, 02:24 PM | #6 |
Hey Free88
I have a buddy here who has lots of good frames. How far north are you? We live in Fergus, just North of Guelph. Doug |
01-09-2006, 03:48 PM | #7 |
Professional Grade
Too bad you arn't over here -- I'd trade you frames swb 2w4 for your swb 4wd frame
01-09-2006, 06:14 PM | #8 |
Me and my fiance were thinking of doing the opposite, converting a 2wd frame to 4x4. We have a donor 4x4 truck complete with everything. But we figured it would be easier to put the 2wd body onto the 4wd frame.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
01-10-2006, 12:16 AM | #9 |
loblazer I am up by Thunder Bay, Ontario. Probably about 16-18 hours drom you. Thanks anyway. If there was a way to get one here, not to expensively i would Get one from you.
