01-05-2006, 03:34 PM | #1 |
Replacement bolts for truck bed
I am going to remove my bed and need to know which bolts I to buy as replacements. I'm sure I'll have to cut the old ones off and replace them. Any help would be great
Thanks |
01-05-2006, 04:14 PM | #2 |
Back in the sticks
Re: Replacement bolts for truck bed
The bolts that hold the bed to the frame are mostly 3/8 x 16, but I would measure them to make sure. The sides and front of the bed are held on with 5/16 x 18. All of them are carriage bolts. Most any hardware store carries them, or you could get a complete set from one of the board vendors. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
01-05-2006, 04:29 PM | #3 |
Thanks Jeff. I need a complete set.
01-05-2006, 04:30 PM | #4 |
www.mar-k.com
This is where I bought a complete set.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
01-05-2006, 09:02 PM | #5 |
The bed to frame bolts are 3/8 by 4 inch. However the front 2 bolts on my 70 were larger, 7/16 by 4, for some reason. Hardware store and some vendors just sell a regular grade 2 bolt, the factory used grade 5 bolts, I would get the stronger grade 5 myself.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-05-2006, 11:18 PM | #6 |
I've found that if you make a small spot weld on the head of the bolt to the bed and soak the threads with BP blaster. you can save them. I do know that LMC carries a complete kit for $15.95
01-06-2006, 12:06 PM | #7 |
I was going to stop by the hardware store on my way home from work and pick them up. so this is what I need 6, 3/8 by 4 inch & 2, 7/16 by 4 grade 5's is this right?
01-06-2006, 12:37 PM | #8 |
I don't now why Green Machine's had the 7/16 bolts Mine had 8 3/8" bolts, I just replaced mine a couple of weeks ago.
70 C/10 SWB Go ahead chance it........Columbus did!!! Steve (Chitlin) Bacon My DIY Shop http://s24.photobucket.com/albums/c47/mpalmiter/shop/ |
01-06-2006, 01:47 PM | #9 |
What do you do for bolts with a wood floor? I know the strips I have are stainless polished. I was going to get stainless bolts and polish them, but you can't get grade 5 in stainless, can you.
Richard Dobson |
01-06-2006, 08:43 PM | #10 |
Richard, if you can't get the bolts in grade 5 from a board vendor then
try this site www.totallystainless.com |
01-06-2006, 10:51 PM | #11 |
"Trucks with Class"
It seems that LWB beds have the two 7/16 bolts up front and SWB have 3/8 bolts in all holes.
