Old 01-05-2006, 06:47 PM   #1
Novaguy73
Novaguy73's Avatar
Goodmark dealers in Iowa?
Anyone that carries the 67-72 sheetmetal? Ill be looking for floors, braces, rockers and cab corners here in a little while and more later on down the road. Id like to buy and help somone local if i could. Anyone? Let me know, thanks...
Novaguy73 is offline   Reply With Quote
Old 01-05-2006, 08:05 PM   #2
Green Machine
Green Machine's Avatar
Re: Goodmark dealers in Iowa?
Try these guys and they are close too, don't know about "goodmark" but they carry tri-plus, my body man gets his stuff from there, they only had the slip on rear cab supports though, not the oem(which you want) I had to get them elsewhere.
http://www.wheelersautobody.com/
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 01-05-2006, 09:22 PM   #3
shifty
Questionable
shifty's Avatar
The goodmark website (I believe) lists vendors?
EDIT: yep, right here: http://www.goodmarkindustries.com/retail.html
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 01-05-2006, 11:01 PM   #4
Novaguy73
Novaguy73's Avatar
Green Machine .Why would somone want the OEM cab supports over the slip on ones? I honestly dont know this is going to be my first shot at any kind of body work and im trying to suck up as much info as i can...also Wheelers is about 5 minutes away...thanks man
BTW is tri-plus a quality manufacturer?
-73' Nova 350 5-speed 9"rear, Runs 11's drives anywhere...
-72' C10 350 Auto 12 bolt, runs 19's?? drives to work!
Old 01-05-2006, 11:33 PM   #5
screamin_c102
screamin_c102's Avatar
Most Goodmark parts are re-labeled Tri-plus parts.
There is a thread somewhere about this.......
screamin_c102 is offline   Reply With Quote
Old 01-05-2006, 11:35 PM   #6
screamin_c102
Yep, here ya go CLICK ME
Old 01-05-2006, 11:50 PM   #7
70c10
67-72 Addict!
70c10's Avatar
I would check with the board vendors first. If that fails, Summit Racing sells Goodmark sheet metal very reasonable and you will save a ton on shipping. Go to Goodmarks website and get your part numbers then go to Summit and type in the part numbers and you will be suprised at the price including shipping on large items.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 01-06-2006, 12:31 AM   #8
Green Machine
Like mentioned above most parts are made by tri-plus regardless of who sells them. There are two kinds of front and rear cab supports, the metal piece. There are the "slip on" which are huge and look like crap, a bandaid, and the ones that are closer to original and look more like original. If I was that close I would sure check out Wheelers.
